Hi guys
My truck has a 3 speed top loader, probably from a 48 F1. Lately when trying to shift out of 1st gear the whole truck bucks, bangs and difficult to pull out of gear. I can start off in second with no problem and shift into third no problem. On occasion this issue has also happened in reverse. But not as often. Thoughts?
Thanks Andy 1952 F1 |
clutch adjustment?
I had to go through EVERYTHING to get mine manageable. Clutch linkage play, engine mounts, worn out pedal bushing..... etc.
Took care of about 90%. My honest opinion is the slight remaining issue when the clutch is hot is the clutch material itself is crap. |
Thanks guys. Free play seems about right. Guess I’ll have take it to a pro.
I wonder if the mainshaft bearing is on its way out? i.e., things are loose back in the 1st/Rev area.
'52 F-1, EAB flathead |
There can also be a problem with the pilot bearing. If it doesn't allow the input shaft to move free of the flywheel with the clutch released, you will have a problem. |
What Ross F-1 said... Chap
Ok thanks guys! Plenty of GL4. It’s my daily driver and all you described is over my ability. I’ll get it to a pro.
#9 | |
And then you'll have a new skill in your bag of tricks. (Or maybe I was just lucky. )
Denny
What can I say except, you da man…. Gonna be getting pretty hot down there in Florida, come on up to NJ, cool down, have a beer or two and help fix this
Damn, I'm already back in Minnesota, or that would be a plan!
Mac VanPelt's early Ford light duty transmission book is very good. It's a good idea to expect to use a press or some other form of bearing pullers for stubborn parts but the difficult part is getting the old style snap rings off. Mac VP has a very good snap ring kit that has the correct thickness rings and they can be removed easily with snap ring pliers.
Removing and reinstalling the transmission is the hardest part. |
#13 |
"rotorwrench" is right on. I should emphasize that my post was not to point out any special skills or talents I have, but to emphasize that these transmissions are quite simple and can be successfully rebuilt by anyone with a minimum of skills, but the ability to to careful work. I would dare say that parts are easier to find these days than they were when I did mine.
I sure wish I had known about Van Pelt Sales when I did mine. |
| Thread Tools | |
| Display Modes | |
