Old 04-29-2021, 07:08 PM   #1
johndee138
johndee138's Avatar
Default 36 LED tail light inserts
I anyone offering LED tail light inserts for a 36?
I don't want or need the housing, trim or lens.
I would prefer white LEDs instead of red, so my blue dots are blue and the license plate illumination is white.
I'm 12v as well.
johndee138 is offline   Reply With Quote
Old 04-30-2021, 04:47 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 36 LED tail light inserts
Retract
Old 04-30-2021, 10:09 AM   #3
Joe Immler
Try Checkrite Electronics I got LED conversion ail lights for my '41 and am very pleased.
Ken Check 541 653 8825 [email protected]
Joe Immler is offline   Reply With Quote
Old 04-30-2021, 10:19 AM   #4
billybronco1
I purchased 6 volt non polarity led 1157 white bulbs on eBay. Just replace standard bulb with led, should work with most directional signal units. I did use a single element for the fronts, they work great, super bright. Still waiting to receive and try the dual elements for the rears. I will post an update once I test them out.
billybronco1 is offline   Reply With Quote
Old 05-01-2021, 10:33 PM   #5
fordor41
fordor41's Avatar
Rodtiques sells LED '36 ford tail light lens. I installed LED lens in my '41. super bright. Mine came from United Pacific. May have to go with no load flasher
fordor41 is offline   Reply With Quote
Old 05-02-2021, 10:06 AM   #6
terry
I needed to do the same as fordor 41 and install a different flasher after i put LED flashers in the back window of my fordor 36. Terry
terry is offline   Reply With Quote
Old 05-02-2021, 03:50 PM   #7
billybronco1
Not sure if the turn signals come standard with a 12 volt bulb in the unit itself, it barely lit up. Took me a while but I found a 6 volt bulb that fit inside the unit, nice and bright now. Directionals also work great with 6 volt third brake light in the rear window.
Old 05-02-2021, 10:02 PM   #8
fordor41
fordor41's Avatar
instead of a no load flasher you can wire in a incandescent bulb in the trunk ,out of sight, on both sides and that will make the regular flasher unit operate
Old 05-14-2021, 06:51 AM   #9
billybronco1
I tried installing LED bulbs in the rear lights and the flasher will not flash. I have LED in the front and a rear window Brakeklighter, with standard bulbs in the rear all works fine. Some people say install a resister. Where would you put the resistor and what size?
