Old 04-22-2021, 04:48 AM   #1
KULTULZ
KULTULZ's Avatar
Post Re: Dual chamber master cylinder for drum brakes
Originally Posted by KULTULZ View Post
The period DUAL RESERVOIR MC(s) you want are 1967-1973 FORD INTERMEDIATE (FAIRLANE-MUSTANG)
CORRECTION - It seems FORD deleted the RPV in their MC after the 1971 model run.
DRUM/DRUM and DISC/DRUM are included for availability I had the chart (from the 1965/1972 MPC), that shows application, manual/power and bore size. The text would also include info regarding the valving used in the period.
I have a current computer problem(s) and will post that info as soon as I can.
If you buy a current production replacement MC, it will most likely not have the RPV(s) in the outlet circuits. You will have to plumb inline valves.
Below are the chart(s) for the 1967-1971 dual reservoir MC (application and bore size) (FAIRLANE - MUSTANG). They originally came with the RPV(s) installed. The valves were not available from FORD separately for service but were included in their MC overhaul kits.
Any current new service replacement (or possibly rebuild) will most likely not have this valve(s) installed.
KULTULZ is offline   Reply With Quote
