Old 03-25-2021, 07:29 AM   #1
bobss396
bobss396's Avatar
Default Re: Dual chamber master cylinder for drum brakes
Originally Posted by KULTULZ View Post
Are you referring to DRUM/DRUM or DISC/DRUM?
Drum-drum for sure. I used a distribution block from Summit with my front disc swap. It has a rear bias adjuster, which I have never had to touch. It runs wide open.
bobss396 is offline   Reply With Quote
Old 03-25-2021, 07:49 AM   #2
KULTULZ
KULTULZ's Avatar
You are referring to what type of 'rear bias adjuster'?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 03-28-2021, 07:34 AM   #3
bobss396
bobss396's Avatar
Similar to this one from Summit.
https://www.ebay.com/itm/Adjustable-...8AAOSwmtZfKZiw
Old 03-28-2021, 10:31 AM   #4
KULTULZ
KULTULZ's Avatar
Question Re: Dual chamber master cylinder for drum brakes
Now wait a minute ...
First you say there is no need for a PPV on a car (DRUM/DRUM I a$$-u-me), then you state you only used a distribution block.
Now you are saying you are using an ADJ BIAS VALVE on your DRUM/DRUM fully opened?
You have a DRUM/DRUM DUAL RESERVOIR MC upgrade?
The last photo below is a FORD (Weatherhead) free-standing PDV (Pressure Differential Valve/Distribution Block of the seventies period (no PROPORTIONING/METERING VALVE). If you do not want the WARNING LAMP, don't use the circuit.
EDIT - ONE MORE TIME
Very simple works for me. There is no reason for a 65 year old car to have a proportioning valve, a basic brass block does the trick.
Are you saying you have an early disc/drum upgrade with no valving on the street?
You know, this why SEMA has to continually fight the FEDS who want to put a stop to owner repair/modifications.
Old 03-29-2021, 07:43 PM   #5
paul2748
paul2748's Avatar
He said it was wide open
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-30-2021, 12:00 AM   #6
KULTULZ
KULTULZ's Avatar
Who's he and what is wide open?
