Old 03-17-2021, 07:43 PM   #1
Jakno
Jakno's Avatar
Default 3 bolt to 2 bolt distributor adapter
Would like to purchase a crab style distributor for my 59A 24 stud engine. Need a 2 to 3 bolt adapter on timing cover. Speed Way, VanPelt and Joe's Antiques are out of them and everything is backordered.
Has anyone purchased one lately ?. ........... Thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 03-17-2021, 08:00 PM   #2
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default Re: 3 bolt to 2 bolt distributor adapter
I need one too..
Tim Carlig
dean333 is offline   Reply With Quote
Old 03-18-2021, 10:38 AM   #3
cas3
when you get one, check the fit before thinking you are ready to bolt it down. mine, and others, have had to file off a bit...i think the corner of the vacuum boss, i forget, but look it over.
Old 03-18-2021, 10:44 AM   #4
TJ
TJ's Avatar
Check with Third Gen Automotive, C and G Parts, or All Ford Parts.
Old 03-18-2021, 10:51 AM   #5
Mart
Mart's Avatar
I just fitted one and I did file the corner of the vacuum boss off. I bought mine 10 years ago so can't help on supplier.
Old 03-18-2021, 11:14 AM   #6
BirchRidge
BirchRidge's Avatar
I’ve sandcast my own in aluminum but since I’m in Sweden I guess that’s to no help
BirchRidge is offline   Reply With Quote
Old 03-18-2021, 12:06 PM   #7
Kube
Super Moderator
Kube's Avatar
Here's a super nice one that you can count on fitting properly.
eBay item number:124637088858
Old 03-18-2021, 12:49 PM   #8
2935ford
2935ford's Avatar
Not to hijack but for information.
Can you use a 2 bolt plate instead of the 3 bolt plate or is there more to it than that?
2935ford is offline   Reply With Quote
Old 03-18-2021, 12:53 PM   #9
Charlie ny
#8...the crab is deeper so even with a 2 bolt cover you'll still need a spacer.
Charlie ny
Old 03-18-2021, 12:53 PM   #10
Kube
Super Moderator
Kube's Avatar
There's more to it than that. The shaft on the distributor that engages the end of the camshaft is longer on '42 - '48 distributors. Thus, the need to "space" it away from the cam.
Old 03-18-2021, 12:56 PM   #11
2935ford
2935ford's Avatar
Thanks all. Great help.
Now I know.
Old 03-18-2021, 01:13 PM   #12
Mart
Mart's Avatar
Re using a 2 bolt plate. Yes you can, but you need a spacer to set the distributer out by the difference between a short cam and a long cam. It's a bit simpler than the 3 to 2 bolt adaptor.
Old 03-18-2021, 01:40 PM   #13
Gary in La.
Gary in La.'s Avatar
I'm confused. The OP stated he is looking for a crab dist for his 59A engine. The 59A engine has a crab dist standard unless somebody installed an early 3 bolt front cover.
Gary in La. is offline   Reply With Quote
Old 03-18-2021, 02:46 PM   #14
35fordtn
35fordtn's Avatar
My thoughts exactly. It must not truly be a 59A, maybe a 39-41 24 stud?
Old 03-18-2021, 02:48 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
Ha! I saw that one last night!! Click the link below for a GOOD chuckle!!! DD
https://www.ebay.com/sch/i.html?_fro...88858&_sacat=0
Click Links Below __
T5 W/TORQUE TUBE
Old 03-18-2021, 02:49 PM   #16
Jakno
Jakno's Avatar
This is the timing cover and Helmet Distributor on my 59A engine. I,m not sure of the year other than it is a 24 stud engine. I bought it "as is " and am attempting to get it running with a reconditioned crab distributor
thanks for all the help and information
Old 03-18-2021, 03:08 PM   #17
39portlander
39portlander's Avatar
Sending a pm with address, thinking your fairly close by...I got one of those kicking around in my V8 pile-O-parts.
Probably will not use it on my pigpen flathead project so hope to help you get yours running. Scott
39portlander is offline   Reply With Quote
Old 03-18-2021, 03:56 PM   #18
39portlander
Some pictures of my adapter on the "pigpen", will get it mailed out to you Jake.
Makes it especially nice knowing it will contribute to keeping a Walt Dupont built Flathead running again
Old 03-18-2021, 04:10 PM   #19
Mart
Mart's Avatar
You can see the area of the vac port that needs filing. It's very close to the hex on the vac brake.
Old 03-18-2021, 05:35 PM   #20
Charlie ny
Jake,
Check your e mail....I found adapters as well.
Charlie ny
