Hello guys! New member here. I have a 1955 Customline Tudor V8 (272 2bbl).
I am not in the same state as my car right now (work), and trying to do a little research. Does anyone know the axle/spring pad spacing on a stock rear end? I am looking at a Versailles 9" installation that I have already, and cannot seem to find the correct center to center on the original rear end to compare to the Versailles. I don't believe it is a direct bolt in swap, but I am trying to confirm. Any help is appreciated! |
Welcome to the Barn!! Think you will like it here. My avatar is sporting a '55 Ford rear end. The best measurement I could get for you is 421/2" center to center on the perches. It could be + or - a hair. Hope this is close enough for what you are needing. Good luck with your project.
One of my best hot rod buddies lives in LHC during the winter. |
#3 | |
So far, I am loving the Barn! Lots of info. As for LHC - I love it...hard to beat and Hot Rods everywhere! |
#4 | |
When you do relocate the pads take your time welding them. The guy who set up the 8 inch Maverick rear end for my '54 Ranch Wagon showed me a rear end housing that was ruined by the guy who welded the pads in one continuous pass.
#5 | |
LAKEWOOD used to carry spring mounts. Make sure you get the pinion angle dialed in correctly also. What year LINC rear is it?
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
https://billthomasenterprises.com/ (909) 888-7949
| Thread Tools | |
| Display Modes | |
