Old 12-15-2020, 04:24 PM   #81
40larry
Default Re: NEW products available thread
Originally Posted by DavidG View Post
The M only appeared on the forged version and only on those supplied by Moore Drop Forgings, which were in a minority of the originals that I've seen, NOS or used.
I have about 40 originals here I keep for restorations and they are about 90% with the big M. Most of these have come from 1939 and 1940 cars which I have parted out over the years. I will check those restorations book as I think the V8 club expects to see the M during judging.
40larry is offline   Reply With Quote
Old 12-15-2020, 04:35 PM   #82
40larry
Okay I checked the 1938 1939 Book which states that these shackle bars changed in 1939 to the 91A-5468 and increased the length from 1.50" to 1.56" and they were marked with the M for identification. Most likely the reproduction here is 1.50" and is only correct up through 1938.
Old 12-22-2020, 11:17 AM   #83
35fordtn
35fordtn's Avatar
Another new small item. I only made 200 of these and will not make anymore in the future. B-2075 1932-34 Ford front brake actuating pin. Seems like these become lost frequently.
Old 01-15-2021, 02:04 PM   #84
35fordtn
35fordtn's Avatar
Another simple and silly but useful new item. A reproduction of the 32-38 KR Wilson synchronizer hub tool. If you’ve rebuilt one of these you know it can be a pain to compress all 6 springs and balls while sliding the hub into the sleeve. With this tool, as you push the hub down it compresses the springs making it a 3 second job. I use my Kr Wilson one all the time. We only made a limited one time run of them. They are zinc plated.
Old 01-15-2021, 04:05 PM   #85
Zeke3
Zeke3's Avatar
Wow, now I can get rid of the popsicle sticks and hose clamps that I used for this job.
Zeke3 is offline   Reply With Quote
Old 01-26-2021, 10:51 PM   #86
35fordtn
35fordtn's Avatar
Another new one. 1932 Ford v-8 water inlets. Completely CNC machined from aluminum.
Old 01-26-2021, 11:40 PM   #87
ford nut
ford nut's Avatar
super nice.
ford nut is offline   Reply With Quote
Old 03-06-2021, 11:18 AM   #88
Mac VP
Mac VP's Avatar
We just introduced a new item.....the special hardware kit for the Borg Warner overdrive lockout levers. The kit fits all versions of the BW lockout levers. These are the pieces needed to properly clamp the lockout cable to the lever, allowing the lever to rotate without twisting or binding the cable. The special stepped washer and the fine thread bolt (drilled for the wire cable end) are often lost, misplaced, or damaged. You can now buy these pieces, along with the related washers and nut to complete your overdrive transmission installation. Our part number is VP-7689K and is listed in our Overdrive Transmission Parts Prices.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 03-06-2021, 11:20 AM   #89
petehoovie
petehoovie's Avatar
Old 04-15-2022, 01:50 PM   #90
Karl Wescott
Karl Wescott's Avatar
Just a teaser today. In from the foundry:
Door dovetail for Station Wagons 1928-32 front and rear doors (and 1933-34 rear doors only).
Inside door handle for 1932 roadster / phaeton. The importers of the Taiwan ones are sold out and do not expect any for a year or more.
Cabriolet top latch handle 1932-36 (when finished will include roller)
Cabriolet top latch handle 1937-38 (when finished will include roller)
These are all 304 stainless. Next steps are polishing and assembly of the handles. I will post again when finished.
Karl Wescott is offline   Reply With Quote
Old 04-15-2022, 02:34 PM   #91
petehoovie
petehoovie's Avatar
Old 04-16-2022, 09:14 AM   #92
DavidG
DavidG's Avatar
Karl,
Thanks for creating those items!
Old 10-20-2022, 10:02 AM   #93
35fordtn
35fordtn's Avatar
Thought I'd share this. I have been using these on my driver cars as they appear somewhat original compared to the Pete and Jakes etc out there.. Polyurethane shackles that use slotted nuts and original type shackle bars..
https://thirdgenauto.com/product/new...g-shackle-set/
Old 12-15-2022, 01:55 PM   #94
Karl Wescott
1936 Hood latch front catch. "Correct" reproductions from Drake have been unavailable for some time, so I am making these "REPLACEMENT" style without the embossed area. 304 Stainless. Note the hole in the middle is for a rubber bumper.
Old 12-15-2022, 02:47 PM   #95
Newc
Newc's Avatar
Default Re: NEW products available thread '32 Cabriolet door part
Had these made as a few of us cabriolet restorers needed them. The guide the window mechanisms I believe. Each door needs two, a left and a right. Very limited production. Need correct top pivot bolts, made at one time by "True Blue 32' [deceased now]. PM me Newc
Old 12-15-2022, 02:57 PM   #96
petehoovie
petehoovie's Avatar
Old 12-15-2022, 02:58 PM   #97
petehoovie
petehoovie's Avatar
Old 12-15-2022, 09:19 PM   #98
Lawson Cox
Lawson Cox's Avatar
I'll bet that's why they included their phone number on their web site. I'd also bet that if you call that number ( (815) 276-2578 ), they would likely tell you "yes"...or "no"!
Coop: Sarcasm is not a virtue. Amen.
Old 12-15-2022, 10:13 PM   #99
V8COOPMAN
V8COOPMAN's Avatar
Wow.... you had to go back THREE years for that one. Nevertheless, what you refer to as "sarcasm" is only pointing out what MOST folks either overlook, or find too troublesome to undertake by themselves.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 12-16-2022, 11:34 AM   #100
TJ
TJ's Avatar
Karl, thanks for posting and making the '36 hood catch. Had a young guy ask me about a pair at the Albany Swap Meet. Luckily I kept his phone number and called him back yesterday and sent him your way.
