And what accounts for all the bendix springs that have broken while the starter was being powered with 6 volts?
#3 | |
• Nothing is as easy as it looks. • Everything takes longer than you think. • Anything that can go wrong will go wrong. • If there is a possibility of several things going wrong, the one that will cause the most damage will be the one to go wrong. Corollary: If there is a worse time for something to go wrong, it will happen then. • If anything simply cannot go wrong, it will anyway. • If you perceive that there are four possible ways in which a procedure can go wrong, and circumvent these, then a fifth way, unprepared for, will promptly develop. • Left to themselves, things tend to go from bad to worse. • If everything seems to be going well, you have obviously overlooked something. • Nature always sides with the hidden flaw. • Mother nature is a bitch. • It is impossible to make anything foolproof because fools are so ingenious. • Whenever you set out to do something, something else must be done first. • The Light at the end of the tunnel is only the light of an oncoming train.
#4 | |
| Thread Tools | |
| Display Modes | |
