Old 12-23-2020, 08:37 PM   #1
MyTwOfOrDs
Default a good headlight conversion ?
My 46 3 ton has orig everything. What is a non crazy $ way to get more headlight whether by swapping or whatever. I''m not going 12v
MyTwOfOrDs is offline   Reply With Quote
Old 12-23-2020, 08:55 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: a good headlight conversion ?
There are lens reflector units that take H4 bulbs, they can be 6V(many voltages and wattages in H4 bulbs), would be direct fit --no modifications in place of seal beam
Old 12-23-2020, 09:17 PM   #3
JSeery
JSeery's Avatar
But what does it take to power them? Is there enough generator output?
Old 12-23-2020, 09:20 PM   #4
paul2748
paul2748's Avatar
6 volt alternator??
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-23-2020, 09:40 PM   #5
JSeery
JSeery's Avatar
Your best bet is to clean up what you have for starters. Make use all the connections are clean and tight, especially the grounds. Adding additional grounds is a fairly cheap why to improve current flow.
