Old 12-23-2020, 03:08 PM   #1
Rick
Default 1939 transmission shifter
What year shifters will work with a 1939 ford top loader trans. I know the shapes of shifters are different but want to know if any other years will work on a 39 inners . I have two 39 big forks missing shifters. I have the towers.
Thanks, Rick [email protected]
Rick is offline   Reply With Quote
Old 12-23-2020, 03:24 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1939 transmission shifter
Here is a chart I found posted on another thread so looks like 36 & 37 will also.
Old 12-23-2020, 07:02 PM   #3
cas3
the difference is in the length of the bottom between the ball and the end. the reason, the slanted shift towers use shorter shift levers ( on the bottom) and the straight up tower from 37 on up use a longer one
Old 12-23-2020, 07:25 PM   #4
Rick
Thank you for the info, Rick
Old 12-23-2020, 07:34 PM   #5
35fordtn
35fordtn's Avatar
Any 36-39 Ford Car, or 36-50 Pickup would "Fit"
