Old 12-11-2020, 12:53 AM   #1
Prairie Viking
Default 1950 sedan dash wiring
I want to replace the wiring in my 1950 sedan. I'll be keeping it stock with the 6 volt positive ground. For those who have done this, is it best to remove the dash to remove and install that part of the new harness, or will that open up a whole new can of worms?
Prairie Viking is offline   Reply With Quote
Old 12-11-2020, 01:10 AM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 1950 sedan dash wiring
I haven't worked on a 50 sedan but on a 46 Tudor removing the dash made rewiring much easier. There were still connections to be made on the firewall after reinstalling the dash but all doable. Removing the seat is a big help.
Old 12-11-2020, 08:26 AM   #3
Frank Miller
Frank Miller's Avatar
Remove the dash. It will be easier in the long run. As well as some before pictures.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 12-11-2020, 10:02 AM   #4
38coop
Just removing the front seat helps a lot.
38coop is offline   Reply With Quote
Old 12-11-2020, 10:09 AM   #5
54vicky
54vicky's Avatar
if you do decide to do it without removing dash a very good investment would be an LED light of some type.there are a myriad of different styles headband etc.until you try one you will be amazed a the light without the heat.let us know how you make out
54vicky is offline   Reply With Quote
Old 12-14-2020, 06:34 AM   #6
fortyonerag
fortyonerag's Avatar
Remove the seat, heater, radio and glovebox. Also, disconnect the pedal rods. You should be able to work comfortably then. If not, you can always drop the dash then.
fortyonerag is offline   Reply With Quote
