Old 10-27-2020, 08:17 PM   #61
alanp561
alanp561's Avatar
Default Re: Rust Oleum spray cans
I have several spray cans of Rustoleum that I've had for more than two years. About 9 months ago, I turned the cans upside down and every month after that, I would alternate turning them right side up and back upside down. I shake them well when I'm ready to use them and haven't lost any more cans of usable paint.
alanp561 is offline   Reply With Quote
Old 11-08-2020, 11:43 PM   #62
cajunfirehawk
cajunfirehawk's Avatar
Now this spray can issue has gotten worse in my shop I have both a can of WD-40 and a can of Kroil, both have content in them (1/5th of a can?) and will shake up, but neither will spray anything out, no matter any trick I try...
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 11-09-2020, 08:13 AM   #63
Mart
Mart's Avatar
Can you squeeze the cans? they may have lost their pressure/propellant. If you can squeeze the cans you might as well just puncture them and drain the contents into some other handy container.
Old 11-09-2020, 08:33 AM   #64
Will D
Will D's Avatar
Not sure bout the paint but I have saved old wd40 by cross docking with a can of compressed air or air duster. Connect the wd40 to air duster with little red straw. Squeeze both triggers for a minute and the air pressure will equalize between the 2 cans. Disconnect and you can now use that last bit of wd40.
Will D is offline   Reply With Quote
Old 11-09-2020, 02:29 PM   #65
ursus
Brilliant!!
Old 11-09-2020, 02:56 PM   #66
tubman
tubman's Avatar
I hope a new can of compressed air is a lot cheaper than a new can of WD-40.
Old 11-09-2020, 06:05 PM   #67
Will D
Will D's Avatar
Used this method in a pinch when I did not want to make a return visit to a job and had a can of air and a can of wd40 with none....
Old 11-09-2020, 07:12 PM   #68
38bill
38bill's Avatar
Just buy a gallon of WD40 and a spray bottle and your good to go.
38bill is offline   Reply With Quote
Old 11-09-2020, 07:37 PM   #69
fortyfords
fortyfords's Avatar
After painting, I always clean out the nozzle with lacquer thinner or acetone and then blow out the nozzle with air. I never turn the can upside down and after cleaning, I have never had a clogged nozzle.
fortyfords is offline   Reply With Quote
Old 11-11-2020, 09:23 AM   #70
ronn
rustoleum lost me a couple yrs back because of this issue. got tired of returning them to walmart.
ONLY KRYLON FOR ME!
