#41 |
I'll second what Talkwrench said... I installed a set of speed bleeders on my 40 and they worked great! Took about 10 mins. to get the brakes bled, and not having to listen to the wife, girlfriend or daughter bitch about having to pump the pedal was priceless.
#42 | |
#43 |
I always considered brake bleeding a social event!!!
#44 |
But don't forget "social distancing"......6 ft. and the mask! Bleed-on! DD
#45 |
#46 | |
#47 |
I've never had the pleasure of working with non-US brake parts, but from the post here on the Barn it appears they can have multiple issues.
#48 |
#49 |
I'm surprised no one has mentioned using a pressure bleeder. If you can borrow or rent one, that is the best way in my opinon.
#50 |
There is a God ! First.....he invented Jack Daniels.........second I’m finally getting some pedal pressure after starting at rear wheel, but then I went to the front right. No leaks, but some pressure. Ordered new rears from C&G and will be here Monday.
Getting 3” of snow here today so I may not be able to start on the rears. Thx all......Mike |
#51 |
RIGHT rear, LEFT rear, LEFT front, RIGHT front. JMO
Paul in CT |
#52 | |
#53 |
It shouldn't but some of the struggles are familiar. Without speed bleeders I messed around for weeks.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
#54 |
#55 |
#56 |
Start with wheel cylinder farthest away from the master cylinder and end at the closest.
#57 |
Is this how y'all do it "Down Under"? DD
#58 |
I think it would help future generations if we again taught auto mechanics in our high school shop classes. All this "needless bleeding" would stop.
#59 |
Damn that would make it so much easier!
"Came too close to dying to stop living now!" |
#60 |
You guys are beautiful !! LOL
The only reason I went from right rear to right front is that I already had jack stands set up on both. Too lazy to take jack stand down and use at left rear. Plus it was 25º out yesterday with 45 mph wind gusts !! We got 4" of snow yesterday and we're now going to be in the 50's and 60's later this week. Unreal and stupid, but...that's Michigan weather. I'll be back at it again this week some more. I know this shouldn't be this tough to do, but when you've never done it before it's not all that easy. Thx all....Mike |
| Thread Tools | |
| Display Modes | |
