Old 08-22-2020, 06:31 PM   #1
stewgee
stewgee's Avatar
Default Gas tank sizes
Just purchased a sweet 30 A Roadster that had a total frame off resto 2007-2011 and was garaged from then until I acquired it. My question is: did the Roadster have a smaller gas tank than the Coupe? I also have a 30 Coupe. Fuel gauges in both seem to function well but I've always kept a marked dowel stick in the shop just to be sure. The depth of the Roadster tank appears to be about two thirds the depth of the Coupe tank. In Les Andrew's manual it says 11 gallons for the 30-31 Model A. I assume that means all A's. Has anyone ever seen an A with a smaller fuel tank?
stewgee is offline   Reply With Quote
Old 08-22-2020, 07:51 PM   #2
Bob C
Default Re: Gas tank sizes
Maybe one has a flame arrester and one doesn't.
Old 08-22-2020, 09:43 PM   #3
stewgee
stewgee's Avatar
Never thought of that. The Roadster has the spare in the wheel well so it is a little hard to look in the tank. Thanks
Old 08-23-2020, 07:28 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
1930 & 1931 gas tanks all hold 11 gallons and fit the same in all 1930 & '31 body style cowls with one exception. In 1931 the gas shutoff valve was moved into the engine compartment, and those gas tanks have a different gas outlet fitting. Also, early to mid 1930 gas tanks use the 1929 oval instrument panel. Some 1930 trucks used 1929 leftover gas tanks until the stock was depleted.
Bob Bidonde
Old 08-23-2020, 10:57 AM   #5
katy
katy's Avatar
Try a mirror.
Old 08-23-2020, 11:02 AM   #6
Ruth
Good one, Bob.
Ruth
Ruth is online now   Reply With Quote
Old 08-23-2020, 12:14 PM   #7
McMimmcs
McMimmcs's Avatar
The spark arrester would’ve very obvious immediately. It’s Not likely a consideration.
Old 08-23-2020, 12:42 PM   #8
stewgee
stewgee's Avatar
Smile Re: Gas tank sizes
The Roadster does have the spark arrester and the Coupe does not. I'm sure it must to have had one at some point. That is why my "dowel stick gauge" would not go down as far as it does in the Coupe. The spare on the passenger side made it hard to see into the tank. With a small step stool I could see the spark arrester. Thanks everyone for the info
Old 08-23-2020, 05:01 PM   #9
Ruth
And maybe not so much.
Ruth
Old 08-24-2020, 02:57 PM   #10
McMimmcs
McMimmcs's Avatar
And maybe a lot !
