any one know his race number and class so we can keep an ear out for him on the live link.
Lawrie |
Car number 8150. The class is XF/BGRMR. (blown gas rear modified roadster) This is according to the entry list.
Wayno
Life is not a spectator sport. |
If he is running the same car? The number is 8150 and
class XF/BGRMR. Picture was from 2018 after his record run. ![]() Sent from my iPad using Tapatalk |
I take they are running Bonneville this year. Anyone hear the condition of the salt ? A friend is running in flathead modified roadster.
He switched to fuel class after the gas runs.
Car number 1815. XF/BFRMR. Fastest speed, 190.185. |
Lawrie |
Believe car number 1815 may not be the same car but one belonging to Ron San Giovanni, 'JR' NOT 'SR'
So just switch fuel and get a different number and driver? interesting.
The car is designed to for both Ronnie & Ron Jr. to run. They bring multiple engines out to the salt. I'm sure Ronnie will come on after the meet to explain how he does it.
Merc, they change numbers so as to keep all of their records straight. Lawrie, I am not running this meet. I didn't get my changes done and the rest of my life got in the way. KC says HI.
Wayno
Hi Elmo, I miss seeing you guys.
Pete |
#13 |
Hi Wayno, still kicking I see, me too. AT 87 I have to hide from that bug, Take care, be safe, and think flatheads and you'll go to heaven.
Gramps |
#14 |
“Take care, be safe, and think flatheads and you'll go to heaven”.
Gramps Has anybody ever read better advice here ????.......?Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#15 |
Speedweek update 2020. Im happy to report once again the flathead Ford powered Rons Hobby Shop Special {aka the Mistress wife's name for car} once again set a record. We had a lot of issues with the intake my son and I fabricated a long time ago causing a drop in boost by mile number 2 we used JB weld epoxy and blue Permitex silicone sealer to help seal things up the best we could. Doing this helped give us a strong 190 qualifying run when prior to that we were stuck in the 180's. Data still showed we were loosing boost mid run on the qualifier so we decided to speed the blower up a bit adding a couple more pounds of boost which in theory would help give us a top end push even with the loss of boost after mile two. All went well until the blower belt decided it was time to retire! However the speed by mile three was fast enough to get back in impound and the record. The salt conditions were outstanding I feel even better than the surface in 2018.
We all would like to thank the entire SCTA crew for putting on the event. The efforts put forth by the board to even pull off the event Im sure was overwhelming those of us who had the opportunity to run greatly appreciate everything. Since we began running at Speedweek in 2016 we have now set six records. Its a long drive home and we must now quarantine but it was all worth it for sure. This year between my son and I driving we put 19 miles on the engine now take a moment and think about that. Once we have the coarse the car leaves the line under its own power no push off so were running all out each pass each mile to the floor every one of our runs was over 180 MPH by the third mile. Opened her up today to look inside all looks good no surprises. Shes a keeper for sure. Now were getting ready to run at the LTA event next month in Maine our record setting ARDUN which has been sitting since 2017 is going back in the car time to run in the 200 range again. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 Last edited by Ronnieroadster; 08-15-2020 at 07:48 PM. |
#16 |
Thanks for the update Ronnie! Sounds like you did well.
#17 |
Ronnie, thats one strong engine,
Good to hear you did well Lawrie |
#18 |
Ronnie, congratulations to you and Ron junior. The local Connecticut men did well.
#19 |
Awesome job as usual! Ron, what octane & type of fuel are you running?
Thanks Joe |
#20 | |
Shhhhh! That's secret stuff! That's like asking a man how much money he has in the bank, or how often he 'kisses' his wife. DD |
| Thread Tools | |
| Display Modes | |
