Old 07-20-2020, 03:03 PM   #1
jharrellh
jharrellh's Avatar
Default Front Engine Mount Post Length
Curious how long the threaded post should be on a front engine yoke. I suspect mine may have been sheared off and filed, since it seems a little short and has no cotter pin hole. It was mounted with rubber donuts, replacing with the proper spring mount. Thanks!
jharrellh is offline   Reply With Quote
Old 07-21-2020, 09:00 AM   #2
Garagekulture13
Garagekulture13's Avatar
Default Re: Front Engine Mount Post Length
Looks like right at 2"
Sent from my SM-N950U using Tapatalk
Garagekulture13 is offline   Reply With Quote
Old 07-24-2020, 02:23 PM   #3
Gary WA
Gary WA's Avatar
I have some with cotter key holes some without but approximately all are close to 2"+-
www.whidbeymodelaclub.com
Old 07-24-2020, 10:12 PM   #4
jharrellh
jharrellh's Avatar
Thanks so much! Turns out mine was a little short, and on closer inspection had been repaired in the past. Ordered a replacement and all went together without drama. Thanks for the help!
