The Pickup has two left to right cross pieces under the bed that are on the frame where the rear axle kickup occurs and use wedges on the the underside of the frame rail to keep things flat when bolted down. Anyone repop these or have 3 or 4 around? I have one to use for an example to make them up but I wanted to see if they are out there or not .....
Thanks ... |
look at mc master carr website #91152A033 you can purchase 10 for $9.44..... Tobby
i have 2 leftover if you can't order them
Probable the same wedges that they use to change the pinion angle on vehicles with parallel leaf springs.
Thank you gents, especially Tobby - looks like mc master Carr has them and I will order them tomorrow! Thank you very much!
| Thread Tools | |
| Display Modes | |
