Old 07-05-2020, 12:49 PM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default 40-41 Pickup Bed Wedges
The Pickup has two left to right cross pieces under the bed that are on the frame where the rear axle kickup occurs and use wedges on the the underside of the frame rail to keep things flat when bolted down. Anyone repop these or have 3 or 4 around? I have one to use for an example to make them up but I wanted to see if they are out there or not .....
Thanks ...
TomT/Williamsburg is offline   Reply With Quote
Old 07-05-2020, 02:38 PM   #2
tobby
Default Re: 40-41 Pickup Bed Wedges
look at mc master carr website #91152A033 you can purchase 10 for $9.44..... Tobby
tobby is offline   Reply With Quote
Old 07-05-2020, 02:42 PM   #3
tobby
i have 2 leftover if you can't order them
Old 07-05-2020, 04:41 PM   #4
TJ
TJ's Avatar
Probable the same wedges that they use to change the pinion angle on vehicles with parallel leaf springs.
Old 07-05-2020, 09:27 PM   #5
TomT/Williamsburg
Thank you gents, especially Tobby - looks like mc master Carr has them and I will order them tomorrow! Thank you very much!
Old 07-11-2020, 07:42 AM   #6
MN Stumpjumper
MN Stumpjumper's Avatar
Tom, could you please post a picture of the installation of the wedges when you do it. Thank you.
MN Stumpjumper is offline   Reply With Quote
