Old 07-01-2020, 01:28 PM   #1
Dave/Green Bay
Default Compression tester
Does anyone have a recommendation for a compression tester that comes with
an adapter for a Flathead. Everything I see comes with mm adapters. Thanks Dave/Green Bay
Dave/Green Bay is offline   Reply With Quote
Old 07-01-2020, 01:42 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Compression tester
Aren't all spark plugs metric thread? According to Machinery's Handbook (24th ed pg 1650), there are four standard SAE spark plug threads, all metric: M18 x 1.5; M14 x 1.25; M12 x 1.25; and M10 x 1.0
Old 07-01-2020, 01:43 PM   #3
fordwife
All ford v8 heads,flatheads from 39 aand up have 14mm spark plugs. some in the early 30s had 18 mm plugs if I remember right.
fordwife is offline   Reply With Quote
Old 07-01-2020, 01:47 PM   #4
petehoovie
petehoovie's Avatar
Yup! My '34 has 18mm plugs....
Old 07-01-2020, 01:56 PM   #5
Dave/Green Bay
Thanks. Just what I needed. That makes the search much easier.
Old 07-01-2020, 02:40 PM   #6
oldford2
oldford2's Avatar
I bought mine at Harbor Freight
John
oldford2 is offline   Reply With Quote
Old 07-01-2020, 03:44 PM   #7
flatheadmurre
flatheadmurre's Avatar
Model B and real early V8 had 7/8 plugs didnīt they ?
But after that metric.
Old 07-01-2020, 03:51 PM   #8
B-O-B
B-O-B's Avatar
O'Reilly Auto Parts is where I bought mine.
B-O-B is offline   Reply With Quote
Old 07-01-2020, 04:31 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Ones with long rubber hoses tend to give lower readings due to hose expansion, I look for Steel cord in the hoses
Old 07-03-2020, 05:49 AM   #10
Mac VP
Mac VP's Avatar
Don’t forget to check that the adapter for the plug hole doesn’t thread too far down into the opening.....it could hit moving valves. A guy I know used one with a long adapter plug on a fresh built engine and ended up having to replace a valve if I remember correctly.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 07-03-2020, 07:07 AM   #11
34fordy
34fordy's Avatar
7/8" wrench but threads are 18MM
34fordy is offline   Reply With Quote
Old 07-03-2020, 07:54 AM   #12
oldford2
oldford2's Avatar
I think that 100# may slightly expand a rubber hose but it is still 100#. Not reduced. JMHO
John
Old 07-03-2020, 08:57 AM   #13
fordwife
I've been told we ended up with mm spark plug sizes due to the influence of Robert Bosch' an early day electrical engineer and manufacturer, who was of German descent.
Old 07-03-2020, 08:36 PM   #14
grumppyoldman
grumppyoldman's Avatar
Dave when doing the test, have all plugs removed and the throttle wide open for best results. You can test it dry then add a little oil to see if it changes the readings, do one cyl. at a time or the oil can drain by rings and give different results. I bought a Bosch tester from O'Rileys. Al
grumppyoldman is offline   Reply With Quote
Old 07-04-2020, 10:23 AM   #15
Kurt in NJ
Kurt in NJ's Avatar
John
When the gauges are checked to a standard pressure and read the same---then when used to check engine compression they read different, the long soft rubber hosed ones read lower, when you move into the high end recording testers the hoses are short, metal reinforced,and the passage is filled with wires to reduce volume
When testing compression it's not as much about how high the gauge eventually gets, it's more about what happens on the first few compression strokes, and testing all the cylinders the same ---you have to remember that to fire there is only one compression stroke
Old 07-05-2020, 12:52 AM   #16
Tinker
Tinker's Avatar
If you have a 37 21 stud or earlier 18mm plugs. just get one of these for compression checks.
https://www.snydersantiqueauto.com/P...earchByKeyword
If using 18mm I like autolite as they still have screw tops and you can run raja ends.
