Old 06-30-2020, 09:53 PM   #1
Kpar
Kpar's Avatar
Default Re: 6 Volt Flasher
Originally Posted by koates View Post
Keith. Your switch is made by Hella and your wiring is not correct. Terminal 54 connects to the L (load) terminal on the flasher unit. Terminal K connects to the P terminal (pilot light)on the flasher unit. L and R go to the left and right wires for your flasher lamps. Terminal X on flasher unit connects through a 10 amp in line fuse to battery power which is Negative on your Positive ground car. There is a short brown wire that is soldered into the flasher switch which has to be grounded for the pilot light. Pilot light is in the end of the flasher switch arm. Good luck. Regards, Kevin.
Thanks Kevin, Will try again to send you a PM
Keith
Kpar is offline   Reply With Quote
