Old 06-18-2020, 10:45 AM   #1
rayfour
Default Mercury Ignition Key
Hi,
I am looking for someone or a business that can cut a new ignition key for my '46 Mercury. The old one is so worn I have been unable to get working copies cut and it is now so thin I'm worried it may break.
I pulled a door lock and the code is FK852.
This car has been in my family since purchased in August of 1946 for $1,507.00 and I have the bill of sale.
Thanks in advance.
Ray Fournier, New Hampshire
rayfour is offline   Reply With Quote
Old 06-18-2020, 10:57 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Mercury Ignition Key
32phil here can do it. His number is 845-551-5132 in NY.
Old 06-18-2020, 11:08 AM   #3
oldford2
oldford2's Avatar
I agree to call Phil and discuss your situation with him. He can certainly cut a key from the door cylinder but a worn ignition cylinder could be the problem.
John
oldford2 is offline   Reply With Quote
Old 06-18-2020, 11:19 AM   #4
19Fordy
19Fordy's Avatar
Check with a locksmith store in you area who has been in business a long time. It's probably a HURD key blank. I had one made for my 40 Ford a few weeks ago.
The replacement blank is not exactly shaped like the original HURD as it has a round top.
The blank # on the new key blank is 1125 H6
The numbers FK852 are the punch code. Locksmith can make a new key from those codes. Read more here:
https://www.fordbarn.com/forum/showt...eplacement+key
Look here and you will see it's the replacement blank for HURD keys. Cost about $6.50 per key. Of course, you could buy the blank separately but, it will probably still cost you the FULL price of having one made.
https://mysecuritypro.com/FordH6KeyBlanks.aspx
Old 06-18-2020, 03:05 PM   #5
corvette8n
corvette8n's Avatar
I had Phil cut some for me from the codes and they work great.
Old 06-18-2020, 06:19 PM   #6
34fordy
34fordy's Avatar
If the key and cylinder are quite worn it is possible to cut the key a few thousands shallow thereby making up for the wear. Sometimes it is much easier if you have the cylinder "in hand" so you can check and file as you go. And sometimes you get lucky and the key you make to code will work perfectly.
Good luck!
34fordy is offline   Reply With Quote
Old 06-19-2020, 09:31 AM   #7
32phil
Thanks for the kind words Guys !
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
