Old 06-04-2020, 01:41 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Speedway’s Valve Train Components
Originally Posted by TomT/Williamsburg View Post
Looking at purchasing all the valvetrain components, 4-ring pistons and rings from Speedway - any thoughts you might have I would appreciate......
This is for a French block build, .125 over, 4” crank, L100 cam, Charlie NYs top mount distributor, 2 deuces, and heads are still a question mark .....
Thanks .....
Heres my thoughts
Since the bore is going to be .125 over it would be much better running three ring pistons. The reduction is friction alone would be worth any additional cost. Speedways pistons are actually Egge brand cast pistons. You may be able to get a better price by ordering the pistons and rings directly from Egge.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
