Old 04-07-2011, 08:19 AM   #1
hotrodglenn
Default '36 Ford spare tire lock HELP !!!
I know somebody out there has an original spare tire with a lock on it !!
If it's at all possible I could use a picture of it removed from the wheel or if there's a publication with a diagram of one.I'd like to save this one and I don't whant to drill it out.I have a lock smith working on it now but more help would be greatly appreciated..THANKS FORD BARN.....
hotrodglenn is offline   Reply With Quote
Old 04-07-2011, 09:36 AM   #2
James
Default Re: '36 Ford spare tire lock HELP !!!
I could do that. From what perspective would you like a picture?
James is offline   Reply With Quote
Old 04-07-2011, 11:51 AM   #3
hotrodglenn
James
Thank you for the help!! A picture of the lock off the spare would help to see how it's made,I really don't want to distroy it.E-mail me if you can and I know with your help I'll be able to save it...
Glenn
Old 04-07-2011, 01:12 PM   #4
Don Rogers
Don Rogers's Avatar
Will this help?
Don Rogers is offline   Reply With Quote
Old 04-07-2011, 01:36 PM   #5
hotrodglenn
Don
That's the one !!! I'm guessing the two latches are not going in when the key is turned.I'll show this to my locksmith to see if he has a trick to make it work.Thanks a TON !!!!
Glenn
Old 04-07-2011, 07:31 PM   #6
Mike in AZ
Mike in AZ's Avatar
Don, what is the trick to getting the keyed cylinder out?? if that is out, a locksmith should be able to make a key by reading the number on the cylinder??....Mike
Mike in AZ is offline   Reply With Quote
Old 04-07-2011, 09:26 PM   #7
James
I just sent pictures to Glenn, which collectively illustrate the parts shown by Don as a working assembly. After inserting the key, I push inward on the assembly while turning to release the tension on mechanism so that the tabs will retract. Essentially, the locking mechanism is under some tension, and this needs to be "countered" by pushing it inward to get the lock to release. Of course, lots of penetrating oil is helpful if the mechanism is oxidized.
Old 04-07-2011, 10:34 PM   #8
Don Rogers
Don Rogers's Avatar
Mike, There is a set screw on the side of the larger mechanism with the levers. If you remove the set screw, the lock cylinder should come out.
Old 04-08-2011, 05:58 AM   #9
hotrodglenn
What a home run you all made my day !!!
THANKS
GLENN
Old 04-08-2011, 11:07 PM   #10
Mike in AZ
Mike in AZ's Avatar
thanks, Don....Mike
Old 04-09-2011, 04:59 PM   #11
dbrock
In case you need it....I got help with the same situation from a guy in Missouri who has the Hurd key stock for cutting vintage keys etc. let me know .....tnx D.B.
dbrock is offline   Reply With Quote
Old 04-09-2011, 06:05 PM   #12
hotrodglenn
dbrock.....Thanks I'll keep in mind !!!!
