Old 05-18-2020, 07:59 PM   #1
qmdv
qmdv's Avatar
Default Oil gallery plug
Saw this on Ebay. Why this as opposed to countersunk plug
https://www.ebay.com/itm/NEW-1932-48...4d02%7Ciid%3A1
qmdv is offline   Reply With Quote
Old 05-18-2020, 09:52 PM   #2
35fordtn
35fordtn's Avatar
Default Re: Oil gallery plug
That is the front oil galley plug. I have to admit that is my listing...... I had them made to the Ford engineering release drawing for the Part. I have to admit I do not know the reasoning for the shoulder. Maybe a engine expert will chime in..
PS they are available through the link below as well as they are available through Van Pelt Sales.
http://thirdgenauto.com/product/1932...ouldered-plug/
Old 05-18-2020, 10:29 PM   #3
deuce_roadster
deuce_roadster's Avatar
I thought it metered the amount of oil past it, perhaps to the water pumps maybe.
Old 05-18-2020, 10:45 PM   #4
qmdv
qmdv's Avatar
Am impressed that that you had them made not knowing why. I am sure that an engineer at Ford knew why. I have never seen them before.
Old 05-19-2020, 05:39 AM   #5
big job
big job's Avatar
That suppose to meter drip drop oil on the timing gears. Van Pelt has those where I
got mine.
big job is offline   Reply With Quote
Old 05-19-2020, 05:51 AM   #6
Terry,OH
Terry,OH's Avatar
As big job indicates.
Old 05-19-2020, 09:25 AM   #7
qmdv
qmdv's Avatar
got mine.
Hmm. Small leaking at front seal. Could it be?
Old 05-19-2020, 09:34 AM   #8
Jockeyshift41
Jockeyshift41's Avatar
Would a plain plug cause low oil pressure? Just wondering.
Al
Jockeyshift41 is offline   Reply With Quote
Old 05-19-2020, 10:02 AM   #9
GOSFAST
GOSFAST's Avatar
I would suppose that setup is a "stop" for the oil-pressure valve/spring in the valley on the early units and the "groove" allows oil to circulate between the front main and the front cam feed hole, w/o that groove I believe the oil passage would be completely closed off.
Thanks, Gary in N.Y.
P.S. I'm just guessing on this scenario based on the photo of the plug, we rarely build any early units any more! Most are the 8BA style nowadays!
GOSFAST is offline   Reply With Quote
Old 05-19-2020, 02:28 PM   #10
qmdv
qmdv's Avatar
I have a plain plug and 60 pounds pressure with MCF oil pump
Old 05-20-2020, 05:31 AM   #11
JM 35 Sedan
JM 35 Sedan's Avatar
Old Henry put that special plug in there for a good reason, and it just amazes me that most of the knowledgeable folks here on these engines and those who are in business rebuilding these engines have no clue why that extended diameter is on that special plug. I can remember posting this same question over 10 years ago here on the Fordbarn when Shelly ran this, and no one could tell me for sure back then. I'd put my money on what Big Job is saying.
John
Old 05-20-2020, 05:12 PM   #12
Lawrie
Lawrie's Avatar
The oil gets to the timing gears via the flat in the relief valve seat,
Lawrie
Old 05-20-2020, 07:41 PM   #13
eicke
The 8BA I'm in the process of rebuilding had a plain old brass pipe plug.
eicke is offline   Reply With Quote
Old 05-20-2020, 07:55 PM   #14
35fordtn
35fordtn's Avatar
The 8BA engines have the oil relief valve in the oil pump which is likely why they dint have/need the shouldered plug
Old 05-21-2020, 04:43 PM   #15
Ol' Ron
Ol' Ron's Avatar
I'm sure enough oil sprays out from the from main bearing to lubracate everything quite well. you don't need a leakage from the grub screw.
Old 11-11-2020, 12:56 PM   #16
Russ/40
Russ/40's Avatar
I believe the plug with the relief, is downstream from the spring metered valve, serving the duel purpose of terminating the valley tube as well as allowing the metered flow path.
