Old 05-05-2020, 06:55 AM   #2
rich b
rich b's Avatar
Default Re: Front window 1936 5 window
The rubber seal fits into a groove in the windshield frame. I have always removed the windshield, dug out the remains of the old seal, cleaned the groove, and worked the new seal in place. All windshield rubber seals are not created equal. Vintique's version sucked, Drake's worked for me, your results may vary.
You have to remove all the fasteners from the dash and move it back to access the regulator screws.
I have a Drake reproduction regulator for my kid's car; it seems like a good piece; but I have not installed it, so I can't say how good.
Read here that they are "out of stock" at Drake; maybe check the vendors. I got mine from CG.
If you consider a used regulator; be wary and check the teeth in closed position where they are usually stripped or well worn.
