OK Folks, I got my original 53 Monterey radiator out. I'm taking it in on Monday to see if the radiator shop can repair it. Hopefully he doesn't slam the door on me. LOL. I'm not sure why the fan would have beaten the heck out of it?
What do you think? Does it look like a goner? Has anyone had one repaired that looks this bad? Has anyone added a fan shroud to a 52 or 53 model? Fingers crossed. Here's the only new radiator that I have been able to find for my car. It's $714. Shhhhhh, don't tell the wife. http://www.usradiator.com/mercury-1939-1956-car-1952-53-v8-flathead-radiator.html Last edited by 53MERC; 04-25-2020 at 01:09 PM. |
See where the fan penetrated the core, but otherwise think a good shop shouldn't have too much of a problem bringing it back. My '39 was in worse shape than yours, and it came back looking like new. However, it depends on the shop you have access to. I was lucky and hope you will be, too.
do yourself a favor and don’t even bother with the radiator shop ,that core is rotted away and in rough shape ,if your not into original looks ,get the new aluminum one ,for the price you can’t go wrong
Might want to check the motor mounts.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
Re your question about a fan shroud: Looking at your picture we can see that the fan has been pulling through the vast majority of the radiator. I think any improvement in air flow from a shroud would be negligible.
For any shroud to function as intended the fan needs to be at the outlet opening, fan blades half in/half out of the shroud. If the fan is left at its location close to the radiator, a shroud is doing nothing. Unless there is a shroud available with only about 1-1/2 inches of depth, you would need to relocate the fan back away from the radiator to the shroud's outlet. I don't know how that could be done. Last edited by JayChicago; 04-25-2020 at 01:00 PM. |
I am no mechanic. Are new motor mounts a costly repair? Last edited by 53MERC; 04-25-2020 at 01:17 PM. |
#7 | |
Many shops will tell advise that you need a new core. That will be $700+. If the fan chopped into the tubes, that may be your only solution for an original look. If it just bent over the fins, you can straighten them yourself to open the air flow. With nothing more than a metal fingernail file and a few hours you can straighten up the fins. If the leaks are tiny, Barr's Leaks will probably do the job. If the tubes are not too badly crudded up internally, you are back in business.
And, figure out why the fan hit the radiator in the first place. |
#9 | |
#10 | |
It sounds like that may be my only option. It is $714 but looks like the original. Here it is: http://www.usradiator.com/mercury-1939-1956-car-1952-53-v8-flathead-radiator.html |
Guess it boils down to your budget and how "original" you want it to be. Lots of aftermarket alternatives that work well.
Since you have it out, might be worth a trip to the "old guy" for an opinion? |
#12 | |
The new one I found from US Radiator will take a month to receive. Covid has them backed up right now. |
#13 |
Thank you for the input.
#14 |
Its a long time ago but I seem to recall the motor mounts being worn out on this 52 Merc and allowing the fan to contact the radiator. I could be wrong though.
A real old time handy radiator guy did some major repairs on a rad for my 64 Chevy II. He got salvage yard parts from a newer vehicle and basically cut a core to fit my tanks. It bolted right in. looks original and works great. On my 52 the main seam on the tank blew out when I overheated it. My own fault as I had the radiator covered for a winter drive and let it get too hot. I have not taken it to a radiator shop yet but am using the 53 radiator on the 52 for now. Good luck with yours. http://https://youtu.be/KO6QzVe_xGY
https://www.youtube.com/user/roosty6/videos |
#15 |
On further inspection of your picture I can see solder repairs on the tank seam just the same as where mine blew out on the 52. I tried a little soldering on mine but gave it up as I was never much good with solder and would not trust my work on even a low pressure system like this one. Sometimes the expensive option is the cheapest one in the long run.
#16 | |
Next will be a gas tank. Are you able to measure that gas tank that you have sitting in your 53' parts car? Remember the gas tank on Ebay? Heres the measurements that he states in his ad: Tank measures 31 1/2" x 23" x 8" I'm wondering if those measurements match the tank you have before I consider ordering one. Thanks for your help, Doug |
#17 |
Check your motor mounts I had that same think happen to me in 1962
#18 |
I'll check and measure this 53 tank later today.
#19 |
Does anyone make an aluminum one for your car ? If so , how much ?
#20 |
Sound like you have been using it as is ,pretty beat up ! as a tampery measure lay it face down and fill it with washing soda for 2/3 days then water blast it through the top, straighten the fins as the others have said ,you can get a model A plastic Shroud that might fit ,within a 1" of the fan will do or you could cut it , Or you could make one .
| Thread Tools | |
| Display Modes | |
