Old 03-18-2020, 06:04 PM   #1
canadian
Default Re: replace wheels with steel wheels. help please.
B6D9DDCC-455C-426A-98A6-2E60A2DBEE52.jpg. these wheels from 2001 chev tracker, fit flush , the large centre hole in rim permits rim to mount flat/flush with drum. believe it or not.
canadian is offline   Reply With Quote
Old 03-18-2020, 06:59 PM   #2
Randy in ca
Randy in ca's Avatar
Originally Posted by canadian View Post
Attachment 424729. these wheels from 2001 chev tracker, fit flush , the large centre hole in rim permits rim to mount flat/flush with drum. believe it or not.
Most solid wheels with the correct bolt pattern do not have a center hole large enough to fit over the raised ring present on Model A hubs without interference. Adapters used to be available to raise the rest of the hub/drum surface to that of the inner ring. Do these Chevy wheels have a large enough hole, or have you enlarged it?
Randy in ca is offline   Reply With Quote
Old 03-18-2020, 09:50 PM   #3
canadian
yes the rim I am using fits exactly outside that rim, no adapters,
