Re: What in Tarnation?
Originally Posted by cas3
when this rig is done, why not use it for the daily business rig and dump the late model with the bad rear end? years ago i built a 47 diamond T with a 5.9 and a 10 speed twin stick mack tranny , 450 ford rear, chev 1 ton spindles on the T front axle, for the intended use of a roll back tow truck. i had the cab and chassis pretty much done, but before i built the deck the reality sunk in that i really dont do near as much interstate junk hunting as i did years ago, so i sold it. the point of this story is, i have always been mad at myself that i did not just shorten it up and put on a pickup box so i then would not have had to fight with dodge electrical problems just to have a cummins under the hood. give it some thought GB
Well I just don't think there is any comparison between my '92 F350 4x4
466 cu in dually diesel flatbed and the truck I am installing a 210 cu in six , 2 wd, pickup box. manual steering single master cyl drum brakes. The rig you were building was all built from very heavy duty components, and you might not have been 67 years old at that time. I have a 1/2 mile of twisty and very steep gravel road leading to my place and I haul all manner of heavily loaded trailers up here with relative ease with the mighty '92. That said, I have been having a ball with this new project. It just isn't up to the safety and performance of this later diesel.
