Misalignment at the cowl normally would not be the result of hinge pin wear, but rather wear on the hinge wear surfaces. Further, if the hinge is loose, that's a whole different issue. Is the hinge looseness in the door side of the hinge or the cowl side or both?
#2 | |
The hinge itself is not loose. It is tight to both the door and the A pillar. But when I put new hinge pins in, you can see the two hinge pieces moving as I lift the door up and down at the rear. Basically, the front of the door has to go up by about an eighth to 3/16 of an inch. I can't imagine the top of the hinge surface would be worn out that much. But I think the hinge pin hole is worn out to the point that new hinge pins don't solve the problem. |
| Thread Tools | |
| Display Modes | |
