It seems I've neglected to find hardware for my tranmission bellhouse. Can someone clue me in to the the bolt size? Is this a specific Ford hardware?
are you refering to the bolts that hoold the transmission to the bellhouse or the bolts that hold the bellhouse to the flywheel cover???
bell housing to flywheel housing 3/8 X 1" NC, bell housing to transmission 7/16 X 1" NC I could be a little off on the length.
Thanks guys. I needed the hardware for both.
The bellhouse to Transmissions bolts are 1/2" dia x 1 1/4" long with a head that takes a 3/4" wrench.
The bellhouse to flywheel cover bolts are 3/8" dia x 1 1/4" long and the head takes a 9/16" wremch and there (I think) twelve of them. The original head had a dome on it. ken |
You can try www.fordbolts.com
Always one bad decision away from a good time. |
wrong post
The four bellhousing to transmission bolts are Grade 5 (three marks on the head).
| Thread Tools | |
| Display Modes | |
