Old 01-23-2020, 09:43 PM   #21
TinCup
TinCup's Avatar
Default Re: Cap and Comp Jet Helicoil repair
Originally Posted by CT Jack View Post
Take the jets to a plating shop and have a copper or nickel flash put on the fittings. This will easily add .0002" to the surface of the threads. Make sure you put wax in the orifice of the fitting otherwise it will get plugged.
That was my next thought.
TinCup is offline   Reply With Quote
Old 01-24-2020, 12:36 AM   #22
Russ/40
Russ/40's Avatar
If the goal is a good fitting jet, i would tin the threads of the jet carefully with 50/50 solder.
Just don't tighten it too much.
Old 01-24-2020, 12:40 AM   #23
TinCup
TinCup's Avatar
The Challenge was the threads in the bowl were all but gone.
Old 01-24-2020, 01:21 AM   #24
redmodelt
redmodelt's Avatar
I read that 3 times and still miss read it. Sorry about that. Even if you were to install a hel-coil you would still need to drill/tap oversize to install. What about soldering it in place? About the only time it would need to come out again would be full rebuilt.
Old 01-24-2020, 11:34 AM   #25
Russ/40
Russ/40's Avatar
I suggested tinning the jet threads, because I can't imagine getting in there to repair what is left. You wouldn't need much for threads to hold the jet if it's tinned.
Old 01-24-2020, 01:02 PM   #26
F.M.
Both of these are 5mm 75 pitch threads. Checked local auto parts and no luck there. Trying to repair Zenith 3 bottom that I found in a box at an antique store. All I can find is M5 .08.
Ok, Try Brattons, Its in his parts book.. Just as you want..
F.M. is offline   Reply With Quote
Old 01-24-2020, 11:55 PM   #27
redmodelt
redmodelt's Avatar
Where is it listed? I looked on line and didn't see any Heli-coils listed only the tap under carburetors. Or is it just in the printed catalog? Do you have a parts number? We too have a couple of bottoms that could use some work, but not as rare as a Z3 so have not been in any rush to fix.
Thanks
Old 01-25-2020, 09:58 AM   #28
F.M.
Thanks
Did not notice he wanted a Heli-Coil, Thought he wanted a Tap..
Old 01-25-2020, 10:37 AM   #29
redmodelt
redmodelt's Avatar
Bummer, would have been easier fix then some of the suggestions so far.
Re my suggestion about soldering it in; if that jet is screwed in without the gasket it can interfere with the well going all the way down. So a spacer under it might be needed.
