Old 11-11-2019, 06:36 PM   #1
Tveditr
Default Where do I store stuff??
On a 1930 5 window coupe with rumble seat where do you store jack, tire tool, and other necessary stuff to have with you?
Tveditr is offline   Reply With Quote
Old 11-11-2019, 07:09 PM   #2
antiquepa
antiquepa's Avatar
Default Re: Where do I store stuff??
Is there room under the seat...not sure if there is!! I do have a little room under my Roadster, but also have an add-on trunk.
antiquepa is offline   Reply With Quote
Old 11-11-2019, 07:39 PM   #3
Conaway2
Conaway2's Avatar
How about a rear mounted trunk ?
Conaway2 is offline   Reply With Quote
Old 11-11-2019, 08:20 PM   #4
alexiskai
alexiskai's Avatar
On my '29 coupe, the seat just lifts off the riser, so I put down some non-slip mats and a utensil tray and put a tool kit, first aid, jack, etc. in there.
If you wanted to, it wouldn't be too hard to build a toolbox that fit up under the panel above the deck lid, at the expense of a little rear passenger knee room.
Old 11-11-2019, 09:03 PM   #5
oldbird55
Henry Ford never thought about that,he had lots of people to carry his junk.Out of touch with the little people.
oldbird55 is offline   Reply With Quote
Old 11-11-2019, 10:41 PM   #6
Aok
Aok's Avatar
I sold my coupe but I use to keep necessary tools in the rumble seat floor.
Aok is offline   Reply With Quote
Old 11-12-2019, 02:38 AM   #7
redmodelt
redmodelt's Avatar
Under the seat.
Old 11-12-2019, 06:43 AM   #8
springerpete
springerpete's Avatar
I built a tool box that fits between the front bumper braces. Carry tools, oil and some spare parts. Extra water and antifreeze jugs on rumble floor in a box I made so they won';t move around. Fire extinguisher nestles in top when down.
springerpete is offline   Reply With Quote
Old 11-12-2019, 07:02 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
A lot fits under the seat, I have the jack, tools, grease gun, fan, water pump, light bulbs, gasket set, coat hangers, and much more, about all I access is the grease gun, it is on top
Old 11-12-2019, 09:34 AM   #10
DD931
DD931's Avatar
There's a really cool tool box that fits between the front "horns" just in front of the radiator. Looks like it belongs there. That's the good news. The bad news is I don't think they are made anymore. Look at swap meets!!
DD931 is offline   Reply With Quote
Old 11-12-2019, 04:11 PM   #11
CHuDWah
CHuDWah's Avatar
Lots of options:
1. Our 30 Sport Coupe had a recessed pan under the seat (the main seat, not the rumble) - just lift up the bottom cushion to access. I'd guess 5 window is the same. We lined the pan with leftover foam carpet pad to keep stuff from rattling and stored jack, tools, etc.
2. A rear trunk and rack - they can be used with sidemount(s) or mounted with a rear spare using bumper arm extensions
3. There are toolboxes that mount between the front frame horns. There are several versions and some look better than others. Don't think they're still being made but you may be able to find one at a swap meet, eBay, etc.
4. A running board tool box - more common on T but should work on A. Originals are fairly common or you probably can find a modern one that will work. Problem is, you have to drill holes in your running board to mount it. But you can get around that by using a clamp-on "accordian" rack - again, more common on T but should work on A. AFAIK, they're not reproduced but originals are around. Just need to make sure stuff mounted on running board doesn't interfere with opening door(s).
CHuDWah is offline   Reply With Quote
