#21 |
Is anyone aware of a 6V LED bulb suitable for brake light use ??
#22 |
Yes. I have them in my Model A. I bought them from a guy from Australia who is always at Hershey and other swap meets.
1910 Model T Touring 1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
#23 |
Mhsprecher - do you have contact info for the supplier ?
Thanks - Jim |
#24 |
The Model A suppliers such as Brattons and Snyders has LEDs.
#25 |
Just google "6v BA15S bulb". Here's one -
https://www.ledlight.com/63-miniatur...ra-bright.aspx Brake lights should be at least 300 lumens. Warm white better matches incandescent color. |
#26 |
I have the white ones in the parking lights and they work okay but sometimes they drop out, probably a grounding issue. I tried the red one in the stop light but the 32cp bulb was brighter so I stuck with it. Those bulbs are advertised at 450lm but they weren't bright enough for me. |
#27 |
I've read that if you paint the inside of the bucket white instead of silver/metallic/no paint it's more reflective and in turn brighter. Is this true?
#28 |
#29 | |
#30 | |
They are a plugin direct replacement in for the existing stop lamp. I also converted the tail lamp to LED What has really helped though is I installed a LED 3rd stop strip on my truck, on the tailgate. People really notice it, and do not come up behind me close when braking. I highly recommend using one. People are not used to looking for a small round brake light blended in with a license plate. If installing on a car my recommendation is to install it more directly in other drivers line of sight, instead of in the rear window. |
#31 | |
Do you have a picture of adding the 3rd stop strip on your tailgate. Was thinking of doing something similar, or adding in rear window. |
#32 |
I just used Velcro for now to mount it teh brake strip to the tailgate, ran the wiring over to the existing stop/tail wiring and cable tied everything up. Wired it into the teacup tail/stop lamp. Just wanted to mount it quickly without drilling holes to try it. Wish the 3rd brake light also had a tail light in it. Will be permanently mounting it next year. I added clear tubing over the wiring to protect the wiring.
For very rare night driving, I have a farm implement magnetic base battery yellow LED light that I put on the Tailgate, put a very thin piece of vinyl over the magnets so it does not scratch/mar the paint. It can be selectable for flashing or constant on. It is very bright at night. Available on line or at Farm and Fleet/Tractor Supply, might find something suitable at Walmart. I prefer it lower and on the back of the A in others line of sight.. Have been behind As with the 3rd brake light in the windows. Did not think it was as noticeable. Last edited by 30 Closed Cab PU; 11-03-2019 at 10:44 AM. Reason: Added last info. |
#33 |
#34 |
I installed the 1156 style LED red bulb as a brake light, but kept the original style lens with the amber top, as mentioned in post 12. Wow ! It really works well, but when not lit, the brake light looks stock.
Now I’d like to replace the tail and cowl lights with LED bulbs - does anyone know of a source for these ? I’m running the stock 6V electrical system. Many thanks - JIm |
#35 |
Unless you have a high point show car I would go with the all red lens without the word stop (it blocks light). I would also install a second stop light. Using a yellow light for brakes might waste just enough time for other drivers to figure out it is not a turn signal that you would have an accident.
Charlie Stephens |
#36 |
I really try not to drive at night if I have to for some reason I hang one of those large triangular reflectors on the back of my ccpu attached to the canopy posts.
| Thread Tools | |
| Display Modes | |
