Any good sources for Antifreeze-Coolant Propylene Glycol
Seems harder and harder to find. Should I just use everyday antifreeze? Or does that really corrode the bearings? |
Walmart has the Propylene Glycol (the green stuff). Well at least for now. It may be totally outlawed in the future depending on who will be running things.
#3 | |
I bought some at our closest Walmart a few weeks ago.
QMDV,
I live in Massachusetts, and that post resonates a little too close to home. Went to the local Wally's a few months ago, and was shocked to pay $20.00 for two gallons of antifreeze. State DEP put a new tax on it. Thanks Granny Warren! |
A little off topic but, does antifreeze have a shelf life? I have a couple of gallons that have been sitting on shelf for several years.
DD658 |
!Paul in CT |
the sierra antifreez sells for 25 dollars a gallon.
In a 1933 model B or a 1933 v8 engine are 5 gallons proper coolant fill? or should 4.5 gallons be used because over overfill/runnoff?
Here it is $10.89 a gallon concentrated so 50-50 mix makes it $5.45 a gallon usable.
#13 |
antifreeze actually does have a shelf life...sorta, in the big trucks they test it with some paper strips of some sort because it will get corrosive after 5 years or so. not sure if its from all the heating and cooling cycles, or a real shelf life.
#14 |
They have so many kinds on the shelf I'm about ready to go back to alcohol. 4 cars in garage, 3 of them Fords and 4 different requirements for antifreeze. Then you go to buy some and they sell gallons of "works in everything".
#15 |
delet
#16 |
Distilled water is $0.88/gal. here. That is what I use.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
#17 |
It is a bit confusing with how many colours of anti freeze there are now. Besides the old green, I have some red, some yellow. Some recommended for diesel engines. On light duty gas engines I've been using "recycled" anti freeze that I have changed out of my diesel engines. Left to settle and filtered several times it looks pretty good and still tests food for our severe cold winters.
https://www.youtube.com/user/roosty6/videos |
#18 |
just an aside the strips mentioned can be purchased at a swimming pool supply store.they are used to check pool PH works for anti freeze as well
#19 |
I bought a gal. from NAPA this summer,cost around $25/00
#20 |
Regarding shelf life, I'm not sure about the anti corrosion properties but I recently drained the antifreeze out of a boat engine that was winterized 20 years ago. It was clean, still bright green and tested at -50F.
| Thread Tools | |
| Display Modes | |
