Old 09-22-2019, 10:41 AM   #1
cederholm
cederholm's Avatar
Default Head gasket installation
More questions from me. How are you guys installing “sealing” your head gaskets. I have new Feltpro with aluminum heads and a freshly machined block.
Thanks,
Carl
cederholm is offline   Reply With Quote
Old 09-22-2019, 10:54 AM   #2
flatjack9
flatjack9's Avatar
Default Re: Head gasket installation
I use no sealers on my gaskets. Just the studs or bolts.
Old 09-22-2019, 11:26 AM   #3
tubman
tubman's Avatar
I coat mine with regular grease.
Old 09-22-2019, 11:35 AM   #4
RalphM
RalphM's Avatar
Didn’t use anything on the gaskets(composite) , but did put Aviation Permatex on the head bolt threads.
RalphM is offline   Reply With Quote
Old 09-22-2019, 11:53 AM   #5
cederholm
cederholm's Avatar
Thank you guys!
Old 09-22-2019, 01:56 PM   #6
Pete
Smokey discovered it, I do it. Aluminum paint.
Old 09-22-2019, 03:07 PM   #7
3738
3738's Avatar
Grease
3738 is offline   Reply With Quote
Old 09-22-2019, 03:09 PM   #8
Jack E/NJ
Jack E/NJ's Avatar
Grease. Jack E/NJ
Old 09-22-2019, 04:59 PM   #9
oldford2
oldford2's Avatar
x3
john
oldford2 is offline   Reply With Quote
Old 09-22-2019, 07:06 PM   #10
tubman
tubman's Avatar
Of course, I was thinking of the gasket surfaces only; I also use "Permatex" thread sealer on my head bolts.
Old 09-22-2019, 07:54 PM   #11
Ronnieroadster
Ronnieroadster's Avatar
X2 especially if the are Copper head gaskets.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 09-22-2019, 08:05 PM   #12
tubman
tubman's Avatar
I would say that copper head gaskets are not a good choice for an engine with aluminum heads (electrolysis problems).
Old 09-22-2019, 08:17 PM   #13
Tinker
Tinker's Avatar
Also, don't you want the small water hole to the front on both gaskets? Been a few yrs since I had to pull heads. But maybe I'm thinking Y-block head gaskets....
Old 09-22-2019, 09:07 PM   #14
Ronnieroadster
Really ?
Old 09-22-2019, 09:26 PM   #15
Pete
Surely, you jest.
Old 09-22-2019, 10:12 PM   #16
tubman
tubman's Avatar
No, I am not. Composite gaskets have worked fine for me over the years and I wouldn't use anything else.
Elementary high school chemistry : http://www.fenestration.net/pdf_docu...lar-Metals.pdf
Old 09-22-2019, 10:47 PM   #17
Pete
I understand your use of them in your stock engines.
Composite gaskets don't work in race engines with big bores even if they made them.
There are several anti corrosion products available for cooling systems that stop aluminum corrosion.
Old 09-22-2019, 11:00 PM   #18
tubman
tubman's Avatar
I see the problem here. Both you and "Ronnie Roadster" are serious racers. You exist in a whole different world than most of us on here. Look at it this way : The engines in top fuel dragsters are basically completely rebuilt between every round; does this mean that those of us with regular "street" engines should do the same? I think not.
Also, composite big bore gaskets are readily available. My latest build has a 3 5/16" bore and I had no problem finding gaskets. It also has a MAX-1, Edmunds heads and upgraded ignition and carburation systems. I don't consider it a stock engine.
I try to buy all of the reasonably priced flathead finned aluminum heads I can. I pass on the majority of heads I find because of excessive corrosion.
Old 09-23-2019, 06:57 AM   #19
chap52
chap52's Avatar
X2... Easier to deal with the next time you have to open the engine up...Chap
chap52 is online now   Reply With Quote
Old 09-23-2019, 07:00 AM   #20
51 MERC-CT
51 MERC-CT's Avatar
I owned (years ago) several early flatheads with factory equipped aluminum heads and composite gaskets.
About 60% of them corroded and leaked and had to be replaced (with used iron ones) from the junk yard.
Just wonder what caused the corrosion considering that they had composite gaskets.
