Old 09-17-2019, 02:24 PM   #1
SRV49
Default 49 wagon brake drum
Looking for a pair of Rear Brake Drums for a ’49 Wagon (I think they are different than the sedan rear drums). New (or used drums that can be turned a couple of times) would be fine. Suggestions for other alternatives would also be welcome. Thanks.
SRV49 is offline   Reply With Quote
Old 09-17-2019, 02:27 PM   #2
Charlie Stephens
Default Re: 49 wagon brake drum
You should place an ad in the "wanted" section of this site: https://www.fordbarn.com/forum/forumdisplay.php?f=18
Charles Stephens
Old 09-17-2019, 09:45 PM   #3
OldDad
OldDad's Avatar
Welcome to the Ford Barn! Someone here has the answer to your questions, and suggestions for alternatives. A vast resource of early Ford info here.
OldDad is offline   Reply With Quote
Old 09-17-2019, 09:56 PM   #4
JSeery
JSeery's Avatar
Welcome to the Barn!
Old 09-18-2019, 07:49 AM   #5
alanwoodieman
not sure but I believe they are pick up truck drums from the same time period. early ford v8 in Piedmont SC may could help
Old 09-18-2019, 09:21 AM   #6
tommyleea
Are your rear drums/brakes 11 X 1 3/4
tommyleea is offline   Reply With Quote
Old 09-18-2019, 09:58 AM   #7
SRV49
First off, thanks for the “welcome to the Barn” comments and the replies to the thread. I appreciate it. I’m currently away from the car for awhile but when I get back I’ll pull the wheels off and look at & measure the drums. I’ll double check what I find against the ‘stock’ part numbers in the Ford Manuals. In the meantime, if anyone has further thoughts or comments, I’d welcome the input.
Old 09-18-2019, 11:29 AM   #8
tommyleea
Why do you think you need drums?
Old 09-19-2019, 11:55 AM   #9
SRV49
The last time a shop checked the brakes they indicated that the drums could not be turned again. At this point, if shoes or any wheel cylinders need to be replaced, a shop may not (because of liability) want to do any work if the drums are out of spec.
Old 09-19-2019, 12:14 PM   #10
woodiewagon46
I got a pair of brake drums for a '56 Ford from a company called Master Power Brakes, www.mpbrakes.com, 888-251-2353. Might have what you are searching for.
woodiewagon46 is offline   Reply With Quote
