Old 03-20-2011, 05:16 PM   #1
leebros60
Default need pedal info
hi fellas, i need the part #s for 39 ford and merc pedals. also can anyone explain the difference between the two as far as measurements and offsets if there are any? thanx guys Lee
leebros60 is offline   Reply With Quote
Old 03-20-2011, 06:35 PM   #2
jerry grayson
Default Re: need pedal info
They are easy to spot as the part numbers are on the pedals. 39 Ford clutch pedal has 91A-7529-A on it. The brake pedal has 91A-2455 on it. The Mercury pedals may have 99A-xxxx on them. The other parts are the same for both cars. The bracket that the pedals rotate on has 91A-2467 on it.
jerry grayson is offline   Reply With Quote
Old 03-20-2011, 08:29 PM   #3
barnstuf
I have a 1938-1942 Ford/Mercury parts book and it has the following data.
Clutch pedal: 1939 Ford 91A-=7520-A, 1939 Mercury 99A-7520-A.
Brake pedal: 1939 Ford 91A-2455, 1939 Mercury 99A-2455.
barnstuf is offline   Reply With Quote
