If you don't have to worry about damaging paint , I heat the cowl half of hinge red hot where the pins go through . Heating red hot expands the hinge so that the pins can be more easy to remove . If failed attempts have been made at driving the hinge pin out from the bottom , the pin is probably expanded . This is why I prefer drilling the pin part way out from the top side and driving the remainder of the pin out from the top side .
#2 | |
| Thread Tools | |
| Display Modes | |
