#101 | |
#102 |
These are mushroom valves. I’m still struggling with this. Am going to break down and buy the clip removal tool today. Will prolly be two weeks before it arrives...
![]() Sent from my iPhone using Tapatalk |
#103 |
That cone shaped piece is not part of the valve, raise it up and the split keeper will fall out of place( may need a little help).
#104 |
"These are mushroom valves."
Those are not mushroom valves, the cup part (6534) is just part of the rotator. |
#105 |
So I need to slide that cup upwards? I’ll give that a try tomorrow
#106 |
![]() Got the first one out. I leveled up on the fork and gave it a smack with the hammer. That got the keeper to move and the retainers just fell off. From there I levered out the spring aaaaand.... stuck again! ![]() That’s the valve guide from the top. I tried getting on it with the hammer and an extension but no dice. ![]() That’s it in the inside. I can easily get the fork on it now but as it fully engages there is nothing to lever against. Can’t get it to budge. I’ve soaked it with 50/50 and am off to work. Will try again tonight Sent from my iPhone using Tapatalk |
#107 |
Your getting a lesson on how easy some flatheads can be to disassemble!!!!!
![]() A large diameter brass or aluminum rod makes a good drive to get the guides out. |
#108 |
you can now use a crowbar with a block of wood to pry valve out. if you are lucky you wont bend it but i would figure on using new valves anyway.
#109 |
Just get a "conventional" valve spring compressor, those rotators and locks will come right out.
This is how we install all the valves during the reassembly, with a spring compressor. Ours is air-operated but a hand one will get it done also! Thanks, Gary in N.Y. P.S. Here's a shot (again) of the compressor at work, makes life easy.
http://www.stromberg-bulletin.com/me...berg-equipped/ |
#110 |
After you remove the lifters, drill 1/8 inch holes in the lifter bores to make adjustment easy.
Would be nice if those are original Johnson adjustable lifters. Don't throw them away. |
#111 |
And be sure to drill the holes as low as possible so a punch, or drill rod will center in the slot on lifter when adjusting your valves. You’ll see when you finally get one of the lifters out.
#112 | |
I’m going to circle back with you guys when I get to this stage. I’m having trouble getting the guides out still... I’ve got them soaking and give em a whack with a socket from the top every time I go by, but no joy yet Sent from my iPhone using Tapatalk |
#113 |
I think a brass or aluminum rod would be a better driver than a socket.
#114 | |
Trouble is finding one. I’ve looked at my usual stops and they don’t carry them. I’ve got a long socket that I plan on beating to death. Good news is that things are starting to move! Sent from my iPhone using Tapatalk |
#115 |
LOL. I collect up different size and length rods to use. We have a surplus store that handles stock metal that is a good source.
#116 |
For stuff like this, I use a place called "ONLINEMETALS.COM". They have "samples" of just about anything you might want in the $3-$10 range. Be careful to keep your orders small enough so you can specify USPS shipping, or the freight charges will kill you.
#117 | |
Great tip! Sent from my iPhone using Tapatalk |
#118 |
I use the same guide driver as I use on my Harley 45 flathead guides. It uses 11/32" ID guides too. This is a link to the KD 812 set that has an 11/32" driver size. https://www.ebay.com/itm/K-D-Tools-N...UAAOSws7xc0kQi
The KD 918 valve puller would likely work as well but I use it to pull the complete assemblies after I yank the horse shoe clips out.https://www.ebay.com/itm/VINTAGE-FOR...EAAOSwL9hc5ciz |
#119 | |
I see what you mean now. I had one complete assembly that pulled out from the top. Next time I’ll get the clip removal tool and do it that way. Sent from my iPhone using Tapatalk |
#120 | |
Circling back! Finished the valves yesterday. ![]() And the lifters this morning ![]() Now where am I supposed to drill these holes? ![]() Don’t forget to clean up your tools when finished for the day! ![]() Sent from my iPhone using Tapatalk |
| Thread Tools | |
| Display Modes | |
