can someone tell me what rear end was used in the 1955 T-Bird? Dana 30 or 44???
DANA 44 in the 55/56 and FORD 9" in the 57.
It looks like this one...
I just pulled this from a 55 Bird. Not sure if it was the original assembly or not.
I was under the impression that they are Dana 45 assemblys. Using the smaller bearing , lighter duty axles than the big brother Dana 44. As you can see mine is marked with a "C" prior to the 44 casting. "C" for car application? Isnt yours from a truck dmsfrr? Someone on this Forum has a rear assembly out of a truck. Thought the "T" may have meant "truck" application. Oldmics |
I don't think so. (but not much on this car would surprise me anymore)
Here's a link.... You might be thinking of miker98038's '55 T-Bird https://www.fordbarn.com/forum/showthread.php?t=260976 . Last edited by dmsfrr; 04-29-2019 at 04:50 PM. |
#7 | ||
SOURCE- https://en.wikipedia.org/wiki/Dana_44 The 'C' appears to be stamped? |
anybody know what rear end i should put undr my 1955 ford panel i have a flathead V8 and aC4 trans in it
Old thread revived. You probably had a Dana, or with a flathead, maybe the lighter duty Ford rearend. Both are short on parts and expensive to deal with. I know, I’ve got a Dana 44 out of a truck (bigger axles and bearings, common junkyard solution in the day.)
Probably your best bet is to research the later model 8.8 fords. Various ratios, drums or disc, etc. Probably need to relocate the pads to the springs. Do a little searching on the truck sites, there’s more info there. |
Depends on if it's a 1/2 ton panel or something larger. Ford used the big Timken Detroit axles in the heavier duty vehicles up through 1-ton.
| Thread Tools | |
| Display Modes | |
