Old 04-11-2019, 12:17 PM   #1
movinman
Default 239 Y Block Exhaust Manifold Question
I picked up a 54 Ford with a rebuilt 239 and Ford-O-Matic transmission. The car is pretty much all stock, and runs great. I would like to change the single exhaust to dual so I can get a deeper rumble out of it with a set of glasspacks. I would also like to eliminate the crossover exhaust pipe in front of the engine.
Does anyone make an aftermarket set of exhaust manifolds for the 239 that will dump the drivers side behind the engine like the passenger side? Or can I use an exhaust manifold from a 272 or a 292? I have a feeling the ports are most likely different sizes, but I figured I'd ask anyway.
Thanks!
movinman is offline   Reply With Quote
Old 04-11-2019, 02:28 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 239 Y Block Exhaust Manifold Question
99% sure the oem dual exhaust manifolds from any 239+ full-sized car will fit.
The '57+ exh manifolds are a bit larger in diameter but the bolt pattern onto the heads is the same.
Leave out the heat riser valve if it has one.
Someone here who owns one can confirm the overall fit.
Casting number chart...
http://www.y-block.info/casting/exhaust.html
Old 04-11-2019, 02:29 PM   #3
darrell
any y block manifold will fit.doesnt matter the engine size
darrell is offline   Reply With Quote
Old 04-11-2019, 03:12 PM   #4
movinman
Thanks for the info, guys. I really do appreciate it.
Old 04-11-2019, 03:39 PM   #5
dmsfrr
dmsfrr's Avatar
Originally Posted by dmsfrr View Post
...The '57+ exh manifolds are a bit larger in diameter but the bolt pattern onto the heads is the same. ...
Except for the Lincoln / truck style y-block engines, which have a zig-zag bolt pattern.
Old 04-11-2019, 08:09 PM   #6
paul2748
paul2748's Avatar
More than likely you are going to have interference on the drivers side because of the neutral safety switch. The manifold will hit according to everything I have heard.
One solution to duals on a 54 with Fordo is to use the stock left manifold, making a pipe that curves under the manifold. I bought a 54 with Fordo and this is what a prior owner had done and I have seen it on other 54's. I converted my 54 to stick trans so I could use the regular stock dual exhaust manifolds (after a 312 swap)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-12-2019, 05:54 PM   #7
JeffB2
JeffB2's Avatar
Other Solution no clearance issues with these on a '54: https://www.spotlitekustomaccessorie...k_Headers.html In fact the guy running the company has a '54 Ford.
JeffB2 is offline   Reply With Quote
Old 04-12-2019, 08:55 PM   #8
paul2748
paul2748's Avatar
Before you buy, be sure you don't run into the clearance problem noted above
48 Ford Conv
56 Tbird
54 Ford Victoria
