Old 03-07-2019, 02:08 PM   #41
100IH
Default Re: Engine Stand
The best thing about the side mount adapt. is that the weight is close to the column and not extending out with the included leverage. With the high cost of Flywheel housings, I would rather not mount to it as in the image on post 40. My opinion, no question it can be done.
100IH is offline   Reply With Quote
Old 03-07-2019, 03:04 PM   #42
Purdy Swoft
Purdy Swoft's Avatar
Originally Posted by California Travieso View Post
I’m buying the HF Engine Stand. Do you bolt it to the rear of the engine using the holes for the bell housing?
David Serrano
Yes , the Harbor Freight engine stand will bolt up to the flywheel housing bolt holes at the rear of the engine block .
Old 03-07-2019, 03:32 PM   #43
California Travieso
Send a message via Yahoo to California Travieso
Thanks Purdy.
David Serrano
California Travieso is online now   Reply With Quote
Old 03-07-2019, 09:02 PM   #44
Smooth_One
Smooth_One's Avatar
Originally Posted by BILL WILLIAMSON View Post
Dang, Daren, just sold my welding equiptment!!!
Bill
- BILL MONEYBAGS lol
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 03-31-2019, 10:35 AM   #45
Shootinok
Shootinok's Avatar
Anyone know the angle of the exhaust ports if I wanted to make a side mount engine stand adapter?
I don’t have the engine out yet and the adapters I see on the web look like about 45deg.
Is it that simple?
8BA flathead
Shootinok is offline   Reply With Quote
Old 03-31-2019, 11:43 AM   #46
katy
katy's Avatar
I would guess that on an 8BA flathead that they're at 45° to the centreline of the block.
On a Model A the engine stand adapter is usually on the opposite side from the exhaust ports.
Old 03-31-2019, 12:45 PM   #47
Railcarmover
Is it that simple?
8BA flathead
fab in place,its how i built the stand bracket in post 21..dont measure just fit it up and weld..
Railcarmover is offline   Reply With Quote
Old 03-31-2019, 02:18 PM   #48
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
If I am reading your question correctly, the exhaust ports are parallel with the deck and the centerline of the crankshaft. The angle of the exhaust ports are because of the engine's inclination as it is mounted in the frame. If I am also understanding your idea, I would think that mounting on the port side would be a huge detriment when you were adjusting valves. Am I missing something?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-31-2019, 02:53 PM   #49
Railcarmover
He's lashing up an 8BA...catch the pan rail and exhaust port makes sense for side mount bracket
Old 03-31-2019, 06:24 PM   #50
tinman7
tinman7's Avatar
What size engine stand from HF?
tinman7 is offline   Reply With Quote
Old 03-31-2019, 10:15 PM   #51
Shootinok
Shootinok's Avatar
Thanks all !
I meant to ask this in the early V8 section - you guys are really a great wealth of knowledge and your assistance is appreciated.
Old 04-01-2019, 10:14 AM   #52
1929 Red Tudor
1929 Red Tudor's Avatar
If you have a welder heres an option you can make yourself
1929 Red Tudor is offline   Reply With Quote
