Old 03-31-2019, 03:38 AM   #1
56yblock
56yblock's Avatar
Default coil ballast resistor
hello guys,
i changed the coil ballast resistor by a new one
when i start the car and i left it run a few minutes , i touch the coil ballast resistor is hot , do you have any idea where come from the problem?
56yblock is offline   Reply With Quote
Old 03-31-2019, 04:37 AM   #2
56yblock
56yblock's Avatar
Default Re: coil ballast resistor
i replaced by this one...
Old 03-31-2019, 06:46 AM   #3
ponymare
It's normal for them to get hot, some have shields to protect from burning things close to them.
ponymare is offline   Reply With Quote
Old 03-31-2019, 09:35 AM   #4
ahshoe
Hot is good.... smoking hot is not.
ahshoe is offline   Reply With Quote
Old 03-31-2019, 09:38 AM   #5
54vicky
54vicky's Avatar
the job of a resistor is to create resistance and in doing so it creates heat pretty simple
54vicky is offline   Reply With Quote
Old 03-31-2019, 01:11 PM   #6
rotorwrench
rotorwrench's Avatar
It's a ballast. It draws off some current to control what current the coil primary draws in order to get the best performance from the coil. Wire wound resistors of that size require a ceramic cover for heat protection to surrounding equipment. They get hot. They will only smoke if oil or water gets spilled on them.
Old 03-31-2019, 02:51 PM   #7
poolplayer1
Yes, that's the same type of ballast resistor that I put in my 55.It does get pretty hot but not smoking hot.Make sure that you get the metal holder braced against the firewall real tight.That metal holder serves as a heat shield too.
poolplayer1 is offline   Reply With Quote
Old 04-01-2019, 10:04 AM   #8
39deluxecp
39deluxecp's Avatar
why a resister in a '55? is it converted to 12v?
39deluxecp is offline   Reply With Quote
Old 04-01-2019, 10:37 AM   #9
56yblock
56yblock's Avatar
but the coil sometime is hot too after the car running longtime.....is it normal?
Old 04-01-2019, 11:36 AM   #10
rotorwrench
12-volt came along in 1956 or so. They still used the same coil as the 6-volt systems but they put a ballast on it of around 1.3 Ohms or so. The 6-volt cars didn't use a ballast with the late type can style coil. The can types came back in with the 8BA and had been improved over the types used in the model A era so they didn't need a ballast.
The old coil testers had a warm up switch position so that the coil could be tested under normal working conditions. I wouldn't say that they get hot. I'd just say that it is normal for them to be warm. To me, hot will burn your hand immediately. Warm, you can hang onto for a few seconds before it gets uncomfortable. A coil is like an electromagnet that gets turned on and off really fast. When you subject a coil core to electromagnetic forces, it warms right up. If you forget to turn your ignition switch off and the breaker points are closed, the coil can get so hot that it will be damaged over a short time plus the battery will go dead eventually. Under normal use, the coil just gets warm.
Old 04-02-2019, 09:31 AM   #11
54vicky
54vicky's Avatar
I would add to that it sits in a place that is a hot area already so this adds to the heat problem.as Rotor said I also consider hot when smoke comes off my fingers along with being very painful
