View Poll Results: Brake Fluid I Use
| Dot 3 |
21 | 28.77% |
| Dot 4 |
12 | 16.44% |
| Dot 5 |
26 | 35.62% |
| Silicon |
12 | 16.44% |
| Other ? |
2 | 2.74% |
| Voters: 73. You may not vote on this poll | |||
I Use-
Aren't DOT5 and Silicone the same thing???
Yes they are the same. Dot 5.1 is the same as 3 and 4. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
Yes, But I meant dot 5.1 and 3 & 4 are all glycol based and NOT silicone based as dot 5 is.. .
Many old cars sit for long periods of time, and the dot 3,4 and 5.1 all
attract moisture, and if the car sits for long periods, the moisture tends to rust the system, especially the wheel cylinders. The glycol based fluids work OK, if you drive the car monthly to keep the moisture from settling. I use dot 5, silicone based fluid, as it Don't attract moisture, and it don't eat the paint if you happen to spill a drop. .
I put DOT-5 in a '68 Corvette I had and it worked fine for 20 years until I sold the car last fall. However, I have never had so much trouble getting the brakes bled on any other car I owned. I have since gone back to DOT-4. I have an electronic device that will tell you the moisture content of the fluid in your system and whether it is at a marginal level or not. From my experience, the DOT-4 fluid will last at least 10 years (probably more) before it picks up enough moisture to be problematic. At that time, I flush the system and install new fluid. I have "Speed Bleeders" installed in my cars, so that is not a big chore.
Think about this : How many 20 or 30 year old "beaters" on the road are running their original brake fluid installed at the factory? Probably most of them, and I know of no major manufacturer that installs DOT-5. If it were a problem, the legislators and DOT would be all over it, with mandated brake fluid changes, etc. |
Dot 5 for 30+ years in my '46.
No juice! - "the safety of steel from pedal to wheel."
If your going to use Dot 3 you might might well use Dot 4 for the higher boiling point. You can mix them but you might as fell flush the system with new dot 4 fluid.
I would use what your other vehicles use which will probably be dot 4 if they have disc brakes. Your already out of room in your garage.You don't have room two bottles of brake fluid. You could put another 97 carb in that spot! Dot 4 chart. The dry boiling point is new fluid. The wet boiling point is after it has two-years worth of absorbing moisture. This is why you change it every two-year's. Do this flush, especially on your new vehicles with antilock brake controls. You do not want moisture screwing that stuff up. It gets real expensive. Your hydraulics should last forever if you flush the fluid every two-year's. Last edited by Flathead Fever; 12-30-2018 at 04:04 PM. |
#13 |
I found that dot 4 is better than dot 3. This was a durability test on clutch slave cylinders on a rig. The cylinders were failing, a switch to dot 4 made them pass the test ok.
I've used dot 4 on everything ever since. I have dabbled with silicone, but the last car I have that was silicone is now on dot 4 after a brake overhaul a couple of years ago. Mart. |
#14 |
Dot3 is all I have here and use it in every brake system. I don't need even more confusion of keeping 2 types of brake fluid. Bad enough with two types anti freeze and several grades of motor oil.
https://www.youtube.com/user/roosty6/videos |
#15 |
no juice in my 36 pickup
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#16 |
The Reason new vehicles don't use Dot 5, is because Dot 5 does not
work with the Anti Lock Brake System. The super fast pumping action of the ABS causes tiny air bubbles in the fluid. .
#17 | |
Wait...??? DOT 5 can't be mixed with 3-4. But DOT 5.1? Correct me here as I've heard horror stories about DOT5 mixing with dot3/4? https://www.jockeyjournal.com/forum/...p/t-43984.html 5.1 being different Last edited by Tinker; 12-30-2018 at 11:30 PM. |
#18 |
Assumption is the mother of all foul-ups. |
#19 |
DOT 5 is Silicon based, and CANNOT be mixed with other fluids. It also does not absorb water, so it can be a good choice for something that sits in storage for long periods of time.
DOT 3 is basic brake fluid. DOT 4 is the synthetic version of DOT 3, and can be mixed with it. I don't know enough about DOT 5.1 to give rock solid advice. I ran DOT 5 in my mustang for a few decades. Never had a problem.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
#20 |
I had to replace the master cylinder in my 1947 coupe as it rusted out at the bottom with Dot 3 brake fluid 40 years ago, so I replaced the master cylinder and have been using a silicon based dot 5 brake fluid ever since no problems, the only thing when the coupe is in storage I push the brake pedal down hard every now and again.
| Thread Tools | |
| Display Modes | |
