Old 12-26-2018, 12:23 PM   #21
Bob C
Default Re: Question About 8BA Truck Oil Pans
I think a lot of your questions were answered in your July thread, check the link in the second post. https://www.fordbarn.com/forum/showt...starter+plates
Old 12-26-2018, 12:38 PM   #22
Hyvolt
Images from my 8rt teardown last week.
Sent from my LG-LS993 using Tapatalk
Hyvolt is offline   Reply With Quote
Old 12-26-2018, 01:56 PM   #23
leon bee
Thanks everybody, Happy New Year!
leon bee is offline   Reply With Quote
Old 12-26-2018, 08:44 PM   #24
V12Bill
V12Bill's Avatar
I just noticed in the above pictures a spacer between the starter plate and the block. I have an 8BA
in my F1 and I don't have that plate. I do have a large open area above the starter plate which is for F1s, that I can see the back of the flywheel. Do I need that plate? Is it a truck part only? Feeble minds need to know.
V12Bill is offline   Reply With Quote
Old 12-26-2018, 11:56 PM   #25
GB SISSON
GB SISSON's Avatar
That rope seal must have been REALLY effective! Never seen such a clean gravel driveway! Great photos and info here, as I'm leaning in the 8ba direction into an older truck. I think I have all those parts. Thanks, I'll be watching.
Old 12-27-2018, 02:15 PM   #26
leon bee
Originally Posted by 4t8v8 View Post
I believe you will find you'll need a rear sump pan for an F1. The center sump pan was used on cars with independent suspension and it will hit the front axle on a F1. I had a lot of rear seal problems with mine and removed the lower bracket years ago as it was a
nuisance to work around. Never missed it.
I guess you recognize that transmission.
Old 12-27-2018, 02:22 PM   #27
leon bee
So the only bolts off that pan bracket are the same bolts that go through the starter plate and into the bell housing? The whole deal is just to stiffen up the engine/trans unit?
I think I've got everything I'll need whichever way I go, with the exception of the truck pan. Maybe the oil pump suction tube is different for truck?
And I still don't understand the dust cover deal, looks like it's just filling up space.
Old 12-27-2018, 07:10 PM   #28
4t8v8
Yup!
4t8v8 is offline   Reply With Quote
Old 12-27-2018, 11:57 PM   #29
Ross F-1
Ross F-1's Avatar
Is this what you are asking about (below)? It's a "dust seal" for the small bit of crank exposed, but it is between the starter plate and oil pan. It is held in place by the two oil pan bolts that straddle the crank. AFAIK no one sells the rubber seals for them any more.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 12-28-2018, 09:47 AM   #30
40cpe
40cpe's Avatar
The Best (Best brand) gasket set I used a couple of year ago had that seal in it.
Old 12-28-2018, 11:39 AM   #31
1927Tudor
1927Tudor's Avatar
The seals for the dust shield are available from Van Pelts, I received a set in November. The seals for the top of the flywheel cover are not.
1927Tudor is offline   Reply With Quote
Old 12-28-2018, 11:57 AM   #32
Ross F-1
Ross F-1's Avatar
Good to know, although since I'm running the Merc pan I don't use the dust shield.
I can't picture what you mean by "...the seals for the top of the flywheel cover", Tudor?
Old 12-28-2018, 06:29 PM   #33
1927Tudor
1927Tudor's Avatar
The two seals numbered 6422 and 6423 (group numbers) in the picture below are no longer available that I’ve been able to determine. Seals 6424 and 6425 are the ones I was able to source from Van Pelt.
Old 12-29-2018, 11:42 AM   #34
V12Bill
V12Bill's Avatar
That is the plate or dust seal that I am missing.
Old 01-01-2019, 05:54 AM   #35
47 flatbed
47 flatbed's Avatar
Great info. I'm at the point to assemble transmission and engine
47 flatbed is offline   Reply With Quote
Old 02-17-2022, 01:37 PM   #36
36coupe
36coupe's Avatar
I’m pulling up an old thread but can that oil pan be run without the dust seal ?
36coupe is offline   Reply With Quote
Old 02-17-2022, 01:56 PM   #37
Tim Ayers
Curious why only the F-1 series of trucks used that dust shield. I'd assume it has something to do with the 11" clutch that was used.
Old 02-17-2022, 02:18 PM   #38
tubman
tubman's Avatar
Why would you want to do that? Is there some interference between parts? I have a couple of those floating around in my stash that I'll never use.
Old 02-17-2022, 05:33 PM   #39
36coupe
36coupe's Avatar
Wondering if it was needed.
You are helping me out on the other thread.
I learn more stuff everyday about flatheads.
Thanks
Old 02-18-2022, 11:23 AM   #40
Burt Lake Barn
Burt Lake Barn's Avatar
I have a truck pan if you need 0ne. I tried to attach some photos but if they don’t come thru, Drop me an email and I’ll send some pictures.
Burt Lake Barn is offline   Reply With Quote
