Old 11-25-2018, 07:24 PM   #1
sinbad339
sinbad339's Avatar
Default Re: Sport Coupe Rear Window won't stay up
Thanks all for the replies. To replace the studs, I think some (most?) of the top has to come apart to get the straps into the anvil tool to secure new studs. I'll take a look to see if the springs ad/or hooks can be replaced.
And midgetracer, I think humor is almost always helpful.
sinbad339 is offline   Reply With Quote
Old 11-25-2018, 07:37 PM   #2
WHN
I don’t think you have to replace the studs, just the hardware on the window. That’s were the spring clips are. I would try this first. Enjoy.
Old 11-25-2018, 08:21 PM   #3
sinbad339
sinbad339's Avatar
You may be thinking of the "lift-a-dot" fasteners. On these, the part on the window is a simple grommet type ring; no spring or anything. The stud part has a spring and a hook that retracts when the end of the stud is pressed.
Old 11-26-2018, 10:48 AM   #4
WHN
Sorry, I thought you were using Side Curtain Fasteners, “life the dot”, A-37513.
That’s what was used on our rear window when we had the new top installed. Very easy to replace. Enjoy.
