Old 10-18-2018, 08:49 AM   #7
WHN
Default Re: 600w
Originally Posted by Terry, NJ View Post
I used Cornhead grease in my universal joint but only because it , the universal joint, has no "Yellow metal". I don't know where the cornhead sits on the GL scale. GL (Gear lube) To the best of my knowledge, is a scale from 1 to 5 that gear lubes are rated on. GL1 is the earliest (and most primitive) forms of grease. GL1 also has no sulphur content. The sulphur content will wipe out bronze bushings (Yellow metals) So where is the cornhead grease on this scale? Unless you've replaced the sector shaft bushings with needle bearings, I'd be very nervous about using cornhead grease in the steering box. For more info, check "Yesterday's Tractors" sub section Ford 8N.
Terry
The NLGI rating for John Deere Cornhead grease is “0”, or soft grease. Regular grease is rated “2”, or normal grease.
Because it is soft grease it is well suited to be used in places with moving parts because it settles back down after movement stops. Also it is thicker than 600w oil which helps it from leaking or dripping out. Cornhead grease will not effect bronze bushings.
My experience has been that this product works very well in Model A steering boxes and u-joints. No leaks, no problems after many years.
I would be very interested in anyone’s confirmed comments on steering box failures caused by Cornhead grease.
