Old 10-12-2018, 06:53 AM   #1
bobsmanstuff
bobsmanstuff's Avatar
Default 600w
Is 600w gear box oil any different then modern 80-90 w?
bobsmanstuff is offline   Reply With Quote
Old 10-12-2018, 07:11 AM   #2
WHN
Default Re: 600w
My simple answer is “no”.
True 600w oil is designed to be used on steam cylinders and is very thick.
90w oil is designed to be used in modern motorcycle transmissions and rear ends.
If you can’t find 600w oil, some Model A owners use STP in their transmissions and rear ends.
Lighter oil will cause leaking and shifting problems. Enjoy.
Old 10-12-2018, 07:20 AM   #3
bobsmanstuff
Default Re: 600w
Thanks, how about in the steering box?
Old 10-12-2018, 07:25 AM   #4
ryanheacox
ryanheacox's Avatar
Default Re: 600w
Seems like the stuff sold today all claims to be thicker than 80w-90. Brattons says SAE 140, Macs says SAE 250.
I got some from Macs a while ago and it is thicker than regular gear lube although it smells and looks exactly the same.
I also have an old bottle that is even thicker, very dark and without the typical gear lube smell. Not sure where it came from but it looks like the picture on Brattons website.
Old 10-12-2018, 07:28 AM   #5
Glen in Hillman MI
Default Re: 600w
I use a 50/50 blend 90w and STP..
Glen
Glen in Hillman MI is offline   Reply With Quote
Old 10-12-2018, 07:32 AM   #6
WHN
Default Re: 600w
I use John Deere Cornhead grease in steering box and u-joint. Works very well.
Old 10-12-2018, 07:59 AM   #7
Patrick L.
Patrick L.'s Avatar
Default Re: 600w
600W is different than 80-90.
600W is about 180-240 weight. 140 or 250 work just fine. 90 is a bit light.
Old 10-12-2018, 08:26 AM   #8
bobsmanstuff
Default Re: 600w
Thanks everybody.
Old 10-12-2018, 08:37 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Default Re: 600w
Go here to learn about 600 viscosity oil. https://www.mobil.com/English-EG/Ind...r-Cylinder-Oil.
Bob Bidonde
Old 10-12-2018, 08:45 AM   #10
nosoup4u
Default Re: 600w
A lot of tractor collectors use this in gear boxes because when not in motion it becomes more or less solid and doesn't seep out. Available at any Deere ag dealer and probably others too.
https://www.youtube.com/watch?v=7zNhli-J0Gk
nosoup4u is offline   Reply With Quote
Old 10-12-2018, 08:47 AM   #11
JD 1931
JD 1931's Avatar
Default Re: 600w
I use the most thick weight gear oil I can find and add 25% STP...
JD 1931 is offline   Reply With Quote
Old 10-12-2018, 08:58 AM   #12
jhowes
Default Re: 600w
Is there more than one STP. I bought a bottle and when I got home it was rather thin. The old stuff was like Honey, some even called it Honey. Jack
jhowes is offline   Reply With Quote
Old 10-12-2018, 10:12 AM   #13
Patrick L.
Patrick L.'s Avatar
Default Re: 600w
Which one did you buy ? There are different types. I think the fellas here use the old original additive which is like honey.
Old 10-12-2018, 11:52 AM   #14
WHN
Default Re: 600w
Blue bottle and red bottle.
Use the Blue Bottle.
Old 10-12-2018, 01:44 PM   #15
oldforder
oldforder's Avatar
Default Re: 600w
I haven't seen any red bottles for several years now. Do you know where you can find them?
oldforder is offline   Reply With Quote
Old 10-12-2018, 02:02 PM   #16
WHN
Default Re: 600w
Last time I saw it was in Walmart. It is thinner than the STP in the blue bottle.
I don’t know how widely distributed it is.
Old 10-12-2018, 07:12 PM   #17
TZBrown
Default Re: 600w
Tractor Supply
https://www.tractorsupply.com/tsc/pr...rease-00?rfk=1
TZBrown is offline   Reply With Quote
Old 10-14-2018, 08:41 AM   #18
Mike V. Florida
Mike V. Florida's Avatar
Default Re: 600w
YES, there is.
Just a little education,
600W is not a designation of a weight of oil. It is the name of an oil sold by Mobil Oil and has it's roots back to the beginning of industrial revolution.
"Mobil Cylinder oils are high performance high viscosity oils designed for use in enclosed worm gears operating at moderate to high speeds and temperatures, and where heavy loads, slow speeds or high temperatures demand high viscosity oils. They are also intended for use in steam engine cylinder applications. They are formulated from high quality base stocks that are resistant to oxidation and thermal degradation, and the build-up of harmful deposits caused by the high operating temperatures of steam cylinders. They protect against rust and corrosion and provide good film strength and excellent lubricity and they are resistant to water washout."
Now, is there a difference between the generic "600W" sold by the vendors and gear oil, NO.
There are a bunch of "formulas" used by owners and all have been successful.
Old 10-14-2018, 11:10 AM   #19
Jim/GA
Jim/GA's Avatar
Default Re: 600w
This graphic may also help you decide what to do, what to use. The viscosities quoted in the Product Data Sheet above are on the left, SAE Gear Oil numbers on the right.
Jim Cannon
"Have a Model A day!"
Old 10-15-2018, 01:03 PM   #20
MALAK
MALAK's Avatar
Default Re: 600w
Do a forum search on "600w" and you'll probably get more info than you want.
It should be noted that in the transmission the oils viscosity along with technique are what synchronize the gears for grind free shifting. As the viscosity of the oil goes down the technique must go up and at some point no amount of technique will prevent gear grinding during shifts.
Here's what I use.
http://asm-mexico.com.mx/sitio/admin...0912104421.pdf
It's extremely viscous and unlike STP it's not just an additive but actual gear oil.
MALAK is offline   Reply With Quote
