Old 02-25-2011, 03:39 PM   #1
zeffer1940
zeffer1940's Avatar
Default 35 fuel tank removal
Hey gang, I pulling the fuel tank out of my 35 phaeton, got to the fill neck, and i dont see a connector hose...Q- How is the fill neck joined to the tank?? How to seperate it to remove tank??
jeff
zeffer1940 is offline   Reply With Quote
Old 02-25-2011, 04:18 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 35 fuel tank removal
There is a threaded sleeve over the filler neck with a bunch of holes towards the outer end. These holes are intended for the use of a spanner wrench that will hopefully allow you to turn that sleeve and remove the filler neck. You want to spray generous amounts of a good penetrating oil (Kroil, PB Blaster, etc.) in the area where this sleeve threads into the tank maybe a day or two before you try to turn it. It can be a real PITA to get that sleeve and neck off in some cases. Just have patience and let the penetrating oil do it's job before putting the mussel to it.
Note that there is a lead washer inside the threaded opening sandwiched between the end of the sleeve and a flange inside the tank. You will want to replace this with a new lead seal washer when you put your tank back in.
PS.....I like your phaeton! Can you post some additional pictures and give us some history on this car? Maybe you have already done this and I just missed seeing it. Thank you
PSS....just found more pics on the "let's see your '35 post" but no history.
John
Old 02-25-2011, 06:04 PM   #3
FL&WVMIKE
FL&WVMIKE's Avatar
JM ..........................
You can also use a 2" O-Ring, instead of the lead washer. Today's gas might be hard on it, after a while. I am lucky. there is a station, in my neighborhood, that sells non-ethonol gasoline.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 02-25-2011, 07:29 PM   #4
FRANK PKNY
FRANK PKNY's Avatar
The spanner wrench is a #34-216 armstrong made in USA. I got mine from a large tool supply company I think it was MSG If you google it wrench number it might come up , it was about $16.00 as I recall. If you can't find the info by monday email me I have the catalog in my shop and I'll be there Monday.
FRANK PKNY is offline   Reply With Quote
Old 02-26-2011, 06:32 AM   #5
dewickt
dewickt's Avatar
Never was able to get mine loose, ended up pulling the fender off to get the tank out.
Terry
dewickt is offline   Reply With Quote
Old 02-26-2011, 07:37 AM   #6
flatheadfan
flatheadfan's Avatar
I have never done this but I have seen and heard cases where the neck would not come loose no matter what technique was used. To get around this problem the neck of the pipe was cut to allow for the tank to be removed normally without having to pull the fender. When things were put back together a fuel resistant hose was used to connect the two neck pieces back together not unlike a late '37 tank. Again, I have never done this but it appears that it can be done.
Tom
flatheadfan is offline   Reply With Quote
Old 02-27-2011, 08:42 AM   #7
31chevy
31chevy's Avatar
I have 34 pickup with same setup, I soaked it for many days & used a brass drift and hammer & was able to get it off.
31chevy is offline   Reply With Quote
