Old 02-24-2011, 03:36 PM   #21
xxf_mike_xf
Default Re: Fleathead Engine Stands
What were the adjusters at the base used for? for leveling perhaps?
xxf_mike_xf is offline   Reply With Quote
Old 02-24-2011, 04:50 PM   #22
Kohnke Rebabbitting
They screw to the floor on each, and keep the stand from moving. Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 02-24-2011, 05:35 PM   #23
JM 35 Sedan
JM 35 Sedan's Avatar
One of the nicest engine stands that I saw posted here and possibly on the HAMB, was built by Mike Bishop in CA. It had adapters that mounted to the front and back of the block and the block could be rotated 360* while doing relieving, porting or other work. I believe he also had adapters that bolted to both side of the block at the exhaust ports. The block could also be rotated 360* in that position. It had a motor cycle seat to sit on while working on the block. It was very well made. Wish I had saved some of his posted pictures. I tried to contact him about this but he did not answer my PM or Email messages.
John
Old 02-24-2011, 09:34 PM   #24
John Kennedy
John Kennedy's Avatar
OK, so up 'til very recently I had never heard of a KR Wilson stand, much less seen one. Today I go to my neighbours house, and what do I see among the racing Flatties and the old Offenhauser engine collection, is a beautiful K R Wilson on the original base. He showed me all the adapters for it, it does inlines as well as flats. Pretty damn cool piece of equipment!
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 02-25-2011, 08:29 AM   #25
hehillsy
hehillsy's Avatar
Have a look at krwilsontools.com I am sure this will help. Tim
hehillsy is offline   Reply With Quote
Old 02-25-2011, 09:24 AM   #26
Scott H
Scott H's Avatar
That KRWilsontools.com website is cool.
I clicked on the Sale/Trade link and noticed they have one of the engine stands for sale...$1200....probably cost that much extra in freight charges!
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 02-25-2011, 11:30 AM   #27
rotorwrench
rotorwrench's Avatar
A example of the Clayborne stand on the flee-pay.
http://cgi.ebay.com/ebaymotors/1932-...item4cf55d8b1b
Old 02-25-2011, 11:42 AM   #28
Bruce Lancaster
I use a Clayborne, brought back to life after lots of brazing, welding, and seemingly random tabs were added by a previous owner.
It is an extermely good stand that allows the engine to be rotated axially for access to anything.
There is a wartime Ford manual of setting up a high-volume assembly line flathead rebuilding shop that shows endless rows of flatheads moving through the various departments on Claybornes, with boring and valve grinding done on the carts as well as assembly.
End adaptors allow full access for clutch and cam work, and nothing is obstructed.
Old 02-25-2011, 01:47 PM   #29
rotorwrench
The Clayborne was a pretty good idea. It gives support on both ends plus it still allows you to install or remove the camshaft. Hell you can even change the cam bearings. With an oil tray underneath you can catch all the oil slober both coming apart or going together. You can just hoist the motor right up out of it too since it just cradles it to the fittings on each end. They roll OK but they lock two wheels instead of just one like most modern stands. They stay put a little better than the three wheel modern types that usually only lock one wheel.
Kerby
Old 02-25-2011, 04:23 PM   #30
1928Fordman
1928Fordman's Avatar
Here is a picture of my KR Wilson engine stand. I also have the V8-60 adapter for it. The second picture is of a Model A Engine adapter for a modern engine stand. I have a lot of extra pipe and flat plate metal, so if someone would like me to make them one I could.
1928Fordman is offline   Reply With Quote
Old 02-26-2011, 04:58 PM   #31
Tommy Gun
Tommy Gun's Avatar
What a cool enginestand. That KR Wilson website is neat.
Tommy Gun is offline   Reply With Quote
Old 02-27-2011, 02:55 PM   #32
carsick
carsick's Avatar
You can get an adapter from Jim Gordon @ Specialty Ford (626)2882290
carsick is offline   Reply With Quote
Old 02-27-2011, 03:10 PM   #33
carsick
carsick's Avatar
Just trying to be helpful, not trying to advertise for anyone. I paid list price for mine.
Old 03-03-2011, 11:37 AM   #34
35 Woodie
35 Woodie's Avatar
Send a message via ICQ to 35 Woodie
This mount that works with a generic engine stand has always worked well for me.
35 Woodie is offline   Reply With Quote
Old 03-03-2011, 02:32 PM   #35
NealinCA
NealinCA's Avatar
How about a Manzel. They were similar to KRW, but were made of Aluminum to cut down on shipping costs. I found this one on the local Craigslist last year.
We have been using this one that my dad made for years. It supports the engine from both sides. We always worried about hanging an engine from one side...even though I know it has been done forever.
Neal
NealinCA is offline   Reply With Quote
Old 03-07-2011, 02:29 PM   #36
Glenn Thoreson
Glenn Thoreson's Avatar
Originally Posted by sikopal View Post
True, the KR Wilson is a solid stand but not the "only" one, Clayborne built a solid stand for the flathead engine that works well!
Will post a photo of mine later!
Actually, according to the list of suggested shop tools in a war time Canadian Ford publication, the stand shown in the original picture is probably made by Wasco. The tool number X-6000 is listed as a Wasco engine stand, and matches the picture in the book.
Glenn Thoreson is offline   Reply With Quote
Old 03-13-2011, 08:48 PM   #37
the99car
the99car's Avatar
I need that 4 speed AA trany in the picture [email protected]
the99car is offline   Reply With Quote
Old 03-22-2011, 08:03 AM   #38
SUHRsc
SUHRsc's Avatar
This isn't flathead specific... but I picked this up the other night...
its a "Ford Rotunda" with gear driven rotation.... my dad and a friend used it in the 70's to build engines on... did the boring and whatnot right on the stand...
I figure it will fit a flathead nicely.....though not as classy looking as the others..
-WANTED-
CYLINDER HEADS
77-6050B, 81AS - 81SB - 99AS - 99SB - 19AS
SUHRsc is offline   Reply With Quote
Old 03-22-2011, 08:08 AM   #39
Tim Ayers
I have this one as well.
Old 03-27-2011, 01:26 PM   #40
Tman
Originally Posted by Capn John View Post
Stumpy's Fabrication Works makes adapters for a normal engine stand. the adapters bolts to the exhaust side of the block so you negate the chance of breaking the rear of the block. http://stumpysfabworks.zoomshare.com...and%20adapters
I have a small run of these ready to weld that I am finally getting around to. $50 + shipping. The tube is 2 3/8" that fits most generic stands. Since these are unwelded I can customize them somewhat if you like before welding.
I will also ship these unwelded with longer tubes if that suits you better, same price. 3/8" plate, 12.5 punds for shipping wieght.
Not trying to spam, just cleaning shop and these might be handy for someone new to flatheads. I will donate a portion of each sale to Ryan for the cost of running the board.
Tman is offline   Reply With Quote
